Time arithmetics on HTTP headers
I´m getting both "last-modified" (file last change timestamp) and "date" (now) headers from a GET() http request. I use collectHeaders() and I can get the values ok.
They are both in what I think is UTC format (strings):
last-modified: Sun, 04 Dec 2022 21:21:07 GMT
date: Sun, 04 Dec 2022 20:35:22 GMT
I need to perform some calculations and comparison, converting those strings to something "simpler". If converting these strings to datetime objects is not feasible, a string formatted as "YYYYMMDDhhmmss" would do the trick.
Is there any library to convert UTC to a more "usable" format that does not require parsing the string -including converting from "JanFeb...Dec" to "0102...12" ?
That would be parsing, and is not at all difficult to implement.
I recommend parsing to integers m/d/y/h/m/s, then the Arduino TimeLib library can handle the rest.
This is doing the work in terms of date comparison (lower than, greater than) which is enough for my purposes at the time :slight_smile:
// returns a YYYYMMDDhhmmss string from a UTC formatted date (HTTP)
String UTC2Date(String UTCdate) {
  String namesList = "JanFebMarAprMayJunJulAugSepOctNovDec";
  String numbersList = "010203040506070809101112";
  int idx = namesList.indexOf(UTCDate.substring(8,11));
  if (idx == -1) { return "00000000000000"; }
  return UTCDate.substring(12,16) + numbersList.substring(int(idx / 3)*2, int(idx / 3)*2 + 2) + UTCDate.substring(5,7) + UTCDate.substring(17,19) + UTCDate.substring(20,22) + UTCDate.substring(23,25);
Basically parses the UTC string directly for everything but the month, which is converted from the 3-letter abbreviation to its 2-digit value.
