Purpose is to read the time from DS3231, at specific instances of "second" a digital output is to be set either HIGH or LOW.
Libraries used work well.
I use this to read the time:
readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,
&year);
..and this to set the conditions (output HIGH when seconds hit 01, 11, 21, 31, 41, 51):
if (second == 01 || second == 11 || second == 21 || second == 31 || second == 41 || second == 51)
digitalWrite(LED2, HIGH);
..and this to set the conditions for output LOW (when seconds are either 05, 15, 25, 35, 45 or 55):
if (second == 05 || second == 15 || second == 25 || second == 35 || second == 45 || second == 55)
digitalWrite(LED2, LOW);
When adding code below before the if-conditions, the output changes state erratically:
static byte lastSecond = 0;
if ( second == lastSecond ) {
return;
lastSecond = second; // remember what second was last time we looked
What is wrong with this code?
Complete file:
[code]
#include <Wire.h>
#include <RTClibExtended.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP280.h>
#include "Adafruit_HTU21DF.h"
#define DS3231_I2C_ADDRESS 0x68
RTC_DS3231 RTC; //we are using the DS3231 RTC
int analog_ip = A0; // select the input pin for the potentiometer
int LED1 = 13; // select the pin for the LED
int LED2 = 14;
int inputVal = 0; // variable to store the value coming from potentiometer
int old_ip_val = 0; // varialbe to store historic value of analog input.
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val / 10 * 16) + (val % 10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val / 16 * 10) + (val % 16) );
S E T U P
pinMode(LED1, OUTPUT); // Defining LED Pin as output
pinMode(LED2, OUTPUT);
Serial.begin(9600); // Setup Serial Communication.
// set the initial time here below; uncomment second line below; compile and load once, the comment that line again and reload
// DS3231 seconds, minutes, hours, day (sunday = day1), date, month, year
// setDS3231time(30,46,7,5,22,3,18);
S E T T I M E
void setDS3231time(byte second, byte minute, byte hour, byte dayOfWeek, byte
dayOfMonth, byte month, byte year)
// sets time and date data to DS3231
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0); // set next input to start at the seconds register
Wire.write(decToBcd(second)); // set seconds
Wire.write(decToBcd(minute)); // set minutes
Wire.write(decToBcd(hour)); // set hours
Wire.write(decToBcd(dayOfWeek)); // set day of week (1=Sunday, 7=Saturday)
Wire.write(decToBcd(dayOfMonth)); // set date (1 to 31)
Wire.write(decToBcd(month)); // set month
Wire.write(decToBcd(year)); // set year (0 to 99)
Wire.endTransmission();
R E A D T I M E
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
Wire.write(0); // set DS3231 register pointer to 00h
Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
// request seven bytes of data from DS3231 starting from register 00h
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f);
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
M A I N L O O P
void loop(){
inputVal = analogRead(analog_ip); // Reading and storing analog input value.
// following if condition is to check last value with new value if new value = +/-5
// then we are not interested to do anything. For other values we want to it to to -
if (inputVal <old_ip_val-5 || inputVal >old_ip_val+5)
Serial.print("Input Value : ");
Serial.print(inputVal); // Printing Analog input value (0-1023)
Serial.print("\nLED Brightness : ");
Serial.print(inputVal/1); // Printing PWM values for LED (0-255)
Serial.print("\n");
analogWrite(LED1, inputVal/1); // Sending PWM value to LED.
delay(50); // Waiting for a while.
old_ip_val = inputVal; // Storing historic value of analog input.
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
// retrieve data from DS3231
// if based on number of times per minute, use second and lastsecond
// if based on number of times per hour, use minute and lastminute
&year);
/* If measurements faster than once per minute: use lastSecond, second
* If measurements slower than once per minute but faster than once per hour: use lastMinute and minute
return;
lastSecond = second; // remember what minute was last time we looked
