Time based servo Movement using Arduino Yún
I’m using an arduino Yún to get the time from a network.
I’ve created functions that should select a servo angle from a global array of angle values based on the time.
The functions work when I use LEDs instead of servos.
What seems to happen here is that an initial time in the serial monitor is given and then the arduino freezes.
I’ve attached a code snippet of a condensed version of what I’m trying to do.
Any help would be appreciated.
Josh
#include <Process.h>
#include <Servo.h>
Servo myServo1;
Process date;                 // process used to get the date
int hours, minutes, seconds;  // for the results
int lastSecond = -1;          // need an impossible value for comparison
int originAngle = 0;
int angles [9] ={25,40,55,70,75,90,105,120,135};
int switchState = 0;
  Bridge.begin();        // initialize Bridge
  // run an initial date process. Should return:
  // hh:mm:ss :
  if (!date.running()) {
    date.begin("date");
    date.addParameter("+%T");
    date.run();
  pinMode(2,INPUT);
  myServo1.attach(3);
uint8_t  servo1(int hours){
  int h1;
//SERVO 1 ------------
 if(hours >=0 && hours <=9){
  h1 = 0;
 return h1;
 }else if (hours >= 10 && hours <=19){
   h1 = 1;
 return h1;
 }else if (hours >= 20 && hours<=24 ){
   h1 = 2;
 return h1;
void servoMove1(int hours){
  if(servo1(hours) == 0){
    myServo1.write(originAngle);
  }else if(servo1(hours) == 1){
    myServo1.write(angles[0]);
  }else if(servo1(hours) == 2){
    myServo1.write(angles[1]);
void noServo(){
switchState = digitalRead(2);
if(switchState == HIGH){
 servoMove1(hours);
}else{
  noServo();
  if (lastSecond != seconds) { // if a second has passed
    // print the time:
    if (hours <= 9) {
      SerialUSB.print("0");  // adjust for 0-9
    SerialUSB.print(hours);
    if (minutes <= 9) {
    SerialUSB.print(minutes);
    // restart the date process:
      date.begin("date");
      date.run();
  //if there's a result from the date process, parse it:
  while (date.available() > 0) {
    // get the result of the date process (should be hh:mm:ss):
    String timeString = date.readString();
    // get the substrings for hour, minute second:
    String hourString = timeString.substring(0);
    String minString = timeString.substring(3);
    // convert to ints,saving the previous second:
    hours = hourString.toInt();
    minutes = minString.toInt();
    return hours;
    return minutes;
Problem solved.
Servo wasn’t working connected to 5v for some reason and I removed the delays.
Here is the code:
If anybody thinks of a better way to do this please let me know
#include <Servo.h>
Servo myServo1;
  // hh:mm:ss :
    date.begin("date");
    date.run();
  pinMode(2,INPUT);
  myServo1.attach(4);
  int h1;
  h1 = 0;
 return h1;
   h1 = 1;
 return h1;
   h1 = 2;
 return h1;
    myServo1.write(angles[8]);
    myServo1.write(angles[7]);
    myServo1.write(angles[6]);
void noServo(){
 servoMove1(hours);
}else if (switchState == LOW){
  noServo();
    // print the time:
    if (hours <= 9) {
    if (minutes <= 9) {
      date.begin("date");
      date.run();
    return hours;
    return minutes;
