Time between button press
I have wired a microswitch to Pin 1 of the Mega. I need to use it as ON/OFF toggle to drive a load through TIP122, and display the time load was switched ON for. Can someone help me in modifying the Toggle LED code to measure time (in seconds) between ON/OFF? Thanks!!
int inPin = 2;         // the number of the input pin
int outPin = 13;       // the number of the output pin
int state = LOW;      // the current state of the output pin
int reading;           // the current reading from the input pin
int previous = LOW;    // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0;         // the last time the output pin was toggled
long debounce = 200;   // the debounce time, increase if the output flickers
long dur_on = 0;    //the duration between ON/OFF
  pinMode(inPin, INPUT);
  pinMode(outPin, OUTPUT);
  reading = digitalRead(inPin);
  // if the input just went from LOW and HIGH and we've waited long enough
  // to ignore any noise on the circuit, toggle the output pin and remember
  // the time
  if (reading == HIGH && previous == LOW && millis() - time > debounce) {
    if (state == HIGH)
      state = LOW;
      state = HIGH;
  dur_on = (millis() - time)/1000;
  Serial.println(dur_on);
  digitalWrite(outPin, state);
  previous = reading;
Use millis() to record the time it was pressed. On the next press subtract that time from the new value of millis() to get the time elapsed
Where in the code do I use millis()??
Where you want to know when something happened.
If I understand your question right, this might do the trick. I just added some code to your loop. I didn't run this, there could be a bug or a problem with my logic, however something like this might steer you in the direction you're looking to go:
    // the time
        time = millis();
        if (state == HIGH)
            state = LOW;
            state = HIGH;
    // if the input is high then remember the time and print duration
    // else ignore time reading and continue with loop
    if ((reading == HIGH) && (millis() - time > debounce))
    previous = reading;
Thanks Postholes!
You know that your accuracy will be no better than 2x the switch debounce?
If you need better then perhaps think about light beam interrupt or other short-or-no-bounce sensor?
GoForSmoke: You know that your accuracy will be no better than 2x the switch debounce?
It's not a high accuracy application, so I am using the Bounce library to debounce for about 200ms.. That serves the purpose
it could help?
const int inPin = 2;
const int outPin= 13;
int elapsedtime=0;
int ledstate =LOW;
int switchstate = LOW;
int previous = LOW;
long prevtime = 0;
long dur_on = 0; //duration between on/off
void setup(){
  pinMode(inPin,INPUT);
  pinMode(outPin,OUTPUT);
void loop(){
  switchstate=digitalRead(inPin);
  if ((millis()-prevtime)>debounce){
    if(switchstate!=previous && switchstate==HIGH){
      if (ledstate==LOW){
        digitalWrite(outPin,HIGH);
        prevtime=millis();
        ledstate=HIGH;
      else if(ledstate==HIGH){
        digitalWrite(outPin,LOW);
        ledstate=LOW;
        Serial.print("time between On and off state");
        elapsedtime=((millis()-prevtime)/1000);
        Serial.println(elapsedtime);
         prevtime=millis();
it works, but the value printed in the serial monitor, is always an integer, and even initializing the "elpasedttime" as a float, always ineger values are returned.
vivchawda:
GoForSmoke:
It’s not a high accuracy application, so I am using the Bounce library to debounce for about 200ms… That serves the purpose
It is -only- a problem if you expect more accuracy. I meant that in a goal-engineering sense.
it works, but the value printed in the serial monitor, is always an integer, and even initializing the “elpasedttime” as a float, always ineger values are returned.
You are subtracting one integer value from another, and dividing the integer result by an int. Why you would expect a non-integer result is the mystery. Now, if you divided by 1000.0, instead…
