Time between two pulses not accurate
im trying a code which measures time between 2 pulses of square waves , but the ideally the delay between the pulses should be zero ( no phase shift given) still the delay is between -4us to 8 us .`
enum MeasurementState {
  WAIT_FOR_PIN2_LOW,
  WAIT_FOR_PIN2_RISING,
  WAIT_FOR_PIN3_LOW,
  WAIT_FOR_PIN3_RISING,
  CALCULATE_DELAY,
  RESET_STATE
MeasurementState state = WAIT_FOR_PIN2_LOW;
const unsigned long timeoutMs = 5000;
unsigned long previousMillis = 0;  /
unsigned long time1 = 0;  // timestamp of pin 2 rising edge (micros)
unsigned long time2 = 0;  // timestamp of pin 3 rising edge (micros)
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  previousMillis = millis();
  switch (state) {
    case WAIT_FOR_PIN2_LOW:
      if (digitalRead(2) == LOW) {
        state = WAIT_FOR_PIN2_RISING;
      else if (currentMillis - previousMillis > timeoutMs) {
        Serial.println("Timeout in WAIT_FOR_PIN2_LOW, retrying...");
    case WAIT_FOR_PIN2_RISING:
      if (digitalRead(2) == HIGH) {
        time1 = micros();
        Serial.print("Pin 2 rising edge at: ");
        Serial.print(time1);
        Serial.println(" us -> WAIT_FOR_PIN3_LOW");
        state = WAIT_FOR_PIN3_LOW;
        Serial.println("Timeout in WAIT_FOR_PIN2_RISING, resetting...");
    case WAIT_FOR_PIN3_LOW:
      // Wait until pin 3 is LOW
      if (digitalRead(3) == LOW) {
        Serial.println("Pin 3 is LOW -> WAIT_FOR_PIN3_RISING");
        state = WAIT_FOR_PIN3_RISING;
        Serial.println("Timeout in WAIT_FOR_PIN3_LOW, resetting...");
    case WAIT_FOR_PIN3_RISING:
      // Wait for pin 3 to go HIGH (rising edge)
      if (digitalRead(3) == HIGH) {
        time2 = micros();
        Serial.print("Pin 3 rising edge at: ");
        Serial.print(time2);
        Serial.println(" us -> CALCULATE_DELAY");
        state = CALCULATE_DELAY;
        Serial.println("Timeout in WAIT_FOR_PIN3_RISING, resetting...");
    case CALCULATE_DELAY:
        long delayTime = (long)time2 - (long)time1;
        long finalDelay = 1000000 - delayTime;
        Serial.print("Delay: ");
        Serial.print(finalDelay);
        Serial.println(" us");
        state = RESET_STATE;
    case RESET_STATE:
      if (currentMillis - previousMillis > 1000) {
    default:
According to the code the delay expected is a 100 ms rather than zero.
Taking in account that a minimal interval that can be measured with micros() is a 4us, your result is rather adequate.
That is true for 16MHz AVR Arduino. Is it true for Due?
oops
I always forget to look in which category the question is posted
