I started playing with Arduino recently and I wanted an example of how I would make a code that records the time, but preferably a simple code (I saw some of the timer and I was kind of lost).
can be using light sensor or button.
I don't know if it helps, but I was wondering how long it takes for an object to go and come back to the same place, in seconds.
The internal clock is not really a good "real" clock unless a precision time keeping crystal is on the Arduino board (separate and less sensitive to temperature changes.) These Arduino boards will typically state they have RTC capability. https://www.google.com/search?q=arduino+boards+with+RTC+capability
The answer is, "unknown" or variable. The fastest the main loop will cycle is when the loop is "empty":
Adding function calls and statements in the loop construct will consume time, that is, will increase the overall loop time.
It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
