Time count using millis()
Hi everyone,
I'm trying to apply a time counter using millis() into my system, the part of the code is as followed:
 if (speedrpm > 20)
    lcd.setCursor(0, 0);
    lcd.print(speedrpm);
    seconds = millis()/1000;
    lcd.setCursor(11, 1);
    lcd.print(seconds);
      if (seconds > 60){
        seconds = 0;
        ++minutes;
        lcd.setCursor(8, 1);
        lcd.print(minutes);
      if (minutes > 60){
        ++hours;
        lcd.setCursor(5, 1);
        lcd.print(hours);
        minutes = 0;
The timer starts counting just fine, but I cant seem to figure out a way so that for example, after 60 seconds, the minute will go up by 1 only and wait for the next 60 seconds,can anyone help me with a solution? Also, how do you set the counter back to 0 after for example 60 seconds because I try seconds = 0 and it doesnt work. Thank you very much.
You need to have an unsigned long variable to store a starting value of millis(), and do a subtraction.
It will help to study this excellent tutorial on Blink Without Delay.
Read Robin2’s discussion: Demonstration code for several things at the same time:
You completely reload seconds in seconds=millis()/1000
Setting seconds to zero will be overwriitten in next turn of the loop.
To get hours, minutes, and seconds since the Arduino started:
  minutes = seconds / 60;
  hours = minutes / 60;
  seconds = seconds % 60;
  minutes = minutes % 60;
To get hours, minutes, and seconds since a start time:
static unsigned long startTime = millis();
  seconds = (millis() - startTime) /1000;
To re-start the timer: “startTime = millis();”
