hello
is there any option for aduino like delayNanoseconds ?
what if I want a delay of 0.005 microseconds ? how can I introduce it ?
thanks
hello
thanks
Delaying by anything less than a single clock cycle (62.5 ns at 16MHz or 0.0625us) is always going to be...problematic.
ok, what if I want 0.5 microseconds (500 ns) ?
Eight NOPs
sorry
dind't understood it, eight nops?
Yes, that's right.
Eight of them. One will take 62.5ns, so eight will take 500ns.
ok but how can I write it?
delayMicroseconds(0.5); arduino does not accept decimal numbers on the delay
Do eight simple instructions:
byte x=x+1;
x=x+1;
x=x+1;
x=x+1;
x=x+1;
x=x+1;
x=x+1;
x=x+1;
That's a fraction, not a factorial (!).
You need to use online assembler to use NOP.
Hello
I tried to put in the code delayMicroseconds(0);
and it doesn't show any problems
does it mean that when I write delayMicroseconds(0); it assumes a delay of 62.5 ns ?
Thanks
No, it means that several clock cycles were consumed determining that you didn't really mean to waste time doing nothing.
No.
Did you read the documentation for delayMicroseconds?
so it is not possible to output two different pins at the same time? (or almost the same)
CrossRoads:
byte x=x+1;
x=x+1;
x=x+1;
x=x+1;
x=x+1;
x=x+1;
x=x+1;
x=x+1;
Unless x is declared volatile, the compiler likely will combine the instructions into adding 8.
Any ideas as to why the value doesn't reset to three numbers?
Yes, it is. Search for PortManipulation to learn how.
