Thanks for your help guys! I have commented out that line but still without result. here is the whole code. I am using the blink without delay for testing. I just started using the arduino (again) for a small art project I am working on. eventually I have six solenoid to control. as sensors I use theremins, that is also why I have this code. I am not a programmer but try to put some pieces together and learn via that way.
#include "Statistic.h"
Statistic myStats;
#include <Stdio.h>
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
//! Macro that clears all Timer/Counter1 interrupt flags.
#define CLEAR_ALL_TIMER1_INT_FLAGS (TIFR1 = TIFR1)
//states
#define s_idle_1 1
#define s_push_1 2
#define s_waitOn_1 3
#define s_pull_1 4
#define s_waitOff_1 5
//Pins
int stalag_1 = 13;
#define thereM_1 5
long previousMillis = 0;
const unsigned long interval = 2000;
int ledState = LOW;
Serial.begin(57600);
myStats.clear(); //explicitly start clean
pinMode(stalag_1, OUTPUT);
// pinMode(stalag_2, OUTPUT);
// pinMode(stalag_3, OUTPUT);
// pinMode(stalag_4, OUTPUT);
// pinMode(stalag_5, OUTPUT);
// pinMode(stalag_6, OUTPUT);
pinMode(thereM_1, INPUT);
// pinMode(thereM_2, INPUT);
// pinMode(thereM_3, INPUT);
// pinMode(thereM_4, INPUT);
// pinMode(thereM_5, INPUT);
// pinMode(thereM_6, INPUT);
// hardware counter setup ( refer atmega168.pdf chapter 16-bit counter1)
TCCR1A=0; // reset timer/counter1 control register A
TCCR1B=0; // reset timer/counter1 control register A
TCNT1=0; // counter value = 0
// set timer/counter1 hardware as counter , counts events on pin T1 ( arduino pin 5)
// normal mode, wgm10 .. wgm13 = 0
sbi (TCCR1B ,CS10); // External clock source on T1 pin. Clock on rising edge.
sbi (TCCR1B ,CS11);
sbi (TCCR1B ,CS12);
// timer2 setup / is used for frequency measurement gatetime generation
// timer 2 presaler set to 256 / timer 2 clock = 16Mhz / 256 = 62500 Hz
cbi (TCCR2B ,CS20);
sbi (TCCR2B ,CS21);
sbi (TCCR2B ,CS22);
//set timer2 to CTC Mode
cbi (TCCR2A ,WGM20);
sbi (TCCR2A ,WGM21);
cbi (TCCR2B ,WGM22);
OCR2A = 124; // CTC at top of OCR2A / timer2 interrupt when coun value reaches OCR2A value
// interrupt control
sbi (TIMSK2,OCIE2A); // enable Timer2 Interrupt
volatile byte i_tics;
volatile byte f_ready ;
volatile byte mlt ;
unsigned int ww;
int cal;
int cal_max;
char st1[32];
long freq_in;
long freq_zero;
long freq_cal;
unsigned int dds;
int tune;
int cnt=0;
cnt++;
f_meter_start();
tune=tune+1;
while (f_ready==0) { // wait for period length end (100ms) by interrupt
PORTB=((dds+=tune) >> 15); // kind of DDS tonegenerator / connect speaker to portb.0 = arduino pin8
tune = freq_in-freq_zero;
// use the tune value here for your own purposes like control of servos, midi etc.
// startup
if (cnt==60) {
freq_zero=freq_in;
freq_cal=freq_in;
cal_max=0;
//Serial.print("** START **");
// //---------------------------------------------------------------------- autocalibration
if (cnt % 20 == 10) { // try autocalibrate after n cycles
Serial.print("*");
if (cal_max <= 400) {
freq_zero=freq_in;
//serial.print(" calibration");
freq_cal=freq_in;
cal_max=0;
Serial.println("");
cal = freq_in-freq_cal;
if ( cal < 0) cal*=-1; // absolute value
if (cal > cal_max) cal_max=cal;
Serial.print(cnt);
Serial.print(" ");
if ( tune < 0) tune*=-1; // absolute value
sprintf(st1, " %04d",tune);
//---------------------------------------------------------Standard abweichung wird hier unten berechnet:
long rn = cal;
myStats.add(rn/5.0);
Serial.print(" Count: ");
Serial.print(myStats.count());
Serial.print(" Average: ");
Serial.print(myStats.average(), 4);
Serial.print(" Std deviation: ");
Serial.print(myStats.pop_stdev(), 4);
if (myStats.count() == 12)
myStats.clear();
delay(2);
//----------------------------------------------------------verhalten stalagmites
//stalagmites_1();
//delay(2);
stalagmites_2();
//delay(2);
//stalagmites_3();
//delay(2);
//stalagmites_4();
//delay(2);
//stalagmites_5();
//delay(2);
//stalagmites_6();
//delay(2);
//-----------------------------------------------------------------------STALAGMITES_1 START------------
void stalagmites_1() {
unsigned long currentMillis_1 = millis();
static int state = s_idle_1; //initial state is 1, the "idle" state.
switch (state) {
case s_idle_1:
Serial.print("Time from switch_idle_1: ");
Serial.println(currentMillis_1);
if ((myStats.pop_stdev() > 40) && (myStats.count() > 4)) {
Serial.println("sensor activated");
state = s_push_1;
case s_push_1:
digitalWrite(stalag_1, HIGH);
state = s_waitOn_1;
Serial.print("Time from the switch_s_push_1: ");
//Serial.println(currentMillis_1);
case s_waitOn_1:
//if a certain amoung of time has passed, goto.
Serial.print("Time from switch_s_waitOn_1: ");
if(currentMillis_1 - previousMillis > interval) {
//save the last time the intervall has happened
state = s_pull_1;
Serial.print("Waiting.....");
previousMillis = currentMillis_1;}
case s_pull_1:
digitalWrite(stalag_1, LOW); //turn off
//time = millis(); //remember the current time
state = s_waitOff_1;
Serial.print("Time from the switch_s_pull_1");
state = s_idle_1;
//Serial.println(time);
//-----------------------------------------------------------------------STALAGMITES_1 END------------
//-----------------------------------------------------------------------STALAGMITES_2 START------------
void stalagmites_2()
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(stalag_1, ledState);
//-----------------------------------------------------------------------STALAGMITES_2 END------------
void f_meter_start() {
f_ready=0; // reset period measure flag
i_tics=0; // reset interrupt counter
sbi (GTCCR,PSRASY); // reset presacler counting
TCNT2=0; // timer2=0
TCNT1=0; // Counter1 = 0
//cbi (TIMSK0,TOIE0); // dissable Timer0 again // millis and delay
TCCR1B = TCCR1B | 7; // Counter Clock source = pin T1 , start counting now
// Timer2 Interrupt Service is invoked by hardware Timer2 every 2ms = 500 Hz
// 16Mhz / 256 / 125 / 500 Hz
// here the gatetime generation for freq. measurement takes place:
ISR(TIMER2_COMPA_vect) {
if (i_tics==50) { // multiple 2ms = gate time = 100 ms
// end of gate time, measurement ready
TCCR1B = TCCR1B & ~7; // Gate Off / Counter T1 stopped
cbi (TIMSK2,OCIE2A); // disable Timer2 Interrupt
sbi (TIMSK0,TOIE0); // ensable Timer0 again // millis and delay
f_ready=1; // set global flag for end count period
// calculate now frequeny value
freq_in=0x10000 * mlt; // mukt #ovverflows by 65636
freq_in += TCNT1; // add counter1 value
mlt=0;
i_tics++; // count number of interrupt events
if (TIFR1 & 1) { // if Timer/Counter 1 overflow flag
mlt++; // count number of Counter1 overflows
sbi(TIFR1,TOV1); // clear Timer/Counter 1 overflow flag
thanks again,
best regards
Tom
