I need to use some time functions, but the Time library seems to be missing. I found the timer library, but nothing with the time library.
So where has the time liberary gone to?
Thanks
Thanks
Use TimeLib.h now: GitHub - PaulStoffregen/Time: Time library for Arduino
I'm not sure what you mean by "missing". Did you ever have it installed?
Here's how to install it:
Note that you should use:
#include <TimeLib.h>
instead of:
#include <Time.h>
The reason is there is an unrelated file named time.h that will be used instead of Time.h on case-insensitive operating systems like Windows and macOS. For that reason, the file TimeLib.h was added to the Time library.
pert:
I'm not sure what you mean by "missing". Did you ever have it installed?Here's how to install it:
- Sketch > Include Library > Manage Libraries...
- Wait for download to finish.
- In the "Filter your search..." box, type "time".
- Scroll down through the search results until you see "Time by Michael Margolis". Click on it.
- Click "Install."
- Wait for installation to finish.
- Click "Close".
instead of:
#include <Time.h>
Thank you, no it is not available in the 1.8.7 version of the software. It is also not available in the current version of sloeber, so I have to assume I need to download the library and install it somehow.
ov10fac:
That's correct. It's not bundled with the Arduino IDE. It never has been.
ov10fac:
"Somehow"? I just gave you very clear instructions on how to do this. Did you read them? Did you try them?
