time.h with 1.0.1?
// Simple Time using Time.h
#include <time.h>
setTime(10,62,23,47,2,12);
  Serial.println(hour());
  Serial.print(":");
  Serial.println(minute());
  Serial.println("");
error is setTime was not declared in this scope.
The TimeSerial example give an error of time_t does not name a type.
You need:
#include <Time.h>
Not:
#include <time.h>
time.h is a C library which is totally different from Time.h which is a arduino library (whoever named a library the same as a one of the C base libraries differing by a capital letter should be should be given a stern talking to!!)
Thanks for the quick reply, changed time.h to Time.h and it still gives the same error.
Have you downloaded this: http://www.arduino.cc/playground/Code/Time
Yes, but I see what I did wrong.
I alway download stuff to my desktop and extract to a folder first, (just in case the zip file does not extract to it own folder), in this case, you have to put the zip file into the library folder and extract it there.
The TimeSerial example uses the Serial.print(TIME_REQUEST.BYTE); which is no longer supported, but thats easily fixed.
Edit: Here`s some very basic example code, for proper formatting see the included TimeSerial example.
//Basic Time example, does very little foramtting of the output.
//See the included TimeSerial Example for formatted output.
#include <Time.h>
  //setTime(hr,min,sec,day,month,yr); 13:15:10 6/10/12
  setTime(13,15,10,06,10,12);
  Serial.begin(1200);
  Serial.println("Serial Connected");
  Serial.print("The Day is ");
  Serial.println(day());
  Serial.print("The Month is ");
  Serial.println(month());
  Serial.print("The Year is ");
  Serial.println(year());
  Serial.println("");
  Serial.println("The Time is ");
  Serial.print(hour());
  Serial.print(":");
  Serial.print(minute());
  Serial.print(":");
  Serial.println(second());
  Serial.println("");
  delay(5000);
Lakes: I alway download stuff to my desktop and extract to a folder first, (just in case the zip file does not extract to it own folder), in this case, you have to put the zip file into the library folder and extract it there.
Why is this the case? I'm trying to understand the solution here because I've had inquiries from a couple people that seem to have similar issues with the Time library. I have not been able to duplicate the symptoms myself. Like you, sometimes I'll download a library elsewhere then move it into the library folder, but other times not. I'm not seeing why it should make a difference.
Thanks!
I think its because there`s Time and TimeAlarms folders in the zipfile.
