TIME.h
Lunbuntu 14
on my desktop work perfect (same library)
on the notbook this error
Al runing ubuntu 13 upgraded to 14,
home/max/sketchbook/libraries/Time/DateStrings.cpp:18:18: error: variable ‘monthStr1’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:19:18: error: variable ‘monthStr2’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:20:18: error: variable ‘monthStr3’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:21:18: error: variable ‘monthStr4’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:22:18: error: variable ‘monthStr5’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:23:18: error: variable ‘monthStr6’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:24:18: error: variable ‘monthStr7’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:25:18: error: variable ‘monthStr8’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:26:18: error: variable ‘monthStr9’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:27:19: error: variable ‘monthStr10’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:28:19: error: variable ‘monthStr11’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:29:19: error: variable ‘monthStr12’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:31:22: error: variable ‘monthNames_P’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:37:26: error: variable ‘monthShortNames_P’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:39:16: error: variable ‘dayStr0’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:40:16: error: variable ‘dayStr1’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:41:16: error: variable ‘dayStr2’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:42:16: error: variable ‘dayStr3’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:43:16: error: variable ‘dayStr4’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:44:16: error: variable ‘dayStr5’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:45:16: error: variable ‘dayStr6’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:46:16: error: variable ‘dayStr7’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:48:20: error: variable ‘dayNames_P’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
/home/max/sketchbook/libraries/Time/DateStrings.cpp:49:24: error: variable ‘dayShortNames_P’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
You are using an older version of the library with a newer version of gcc.
The time library has been updated to correct this.
Go get a newer Time library from Paul's site:
https://www.pjrc.com/teensy/td_libs_Time.html
Here is more info:
http://forum.arduino.cc/index.php?topic=254424.0
--- bill
