Hi all, I have been working on a time lapse controller for my DSLR for a couple of weeks. I have got it working OK and I have just added motor control for using a slider using a modded servo. The code is very messy and with lots of spaces here and there but I find it helps me navigate while I'm working on stuff.
I use delays for the intervals so obviously I am jamming up the processor which id rather not so I can do other things.
I have been pondering for the last couple of days over how to change the delays for timed functions but no success yet. I just cant think how it would be done, I need to toggle a pin, wait for time x, then toggle another pin, wait for time y, then turn toggle both pins at the same time, then toggle another pin high, wait for time z, then toggle it again - without re-writing a lot of my code
any help would be good
edit.. code seems to big to post, although i didn't think it was that big!
I'd like to learn how to do it, but I'm new to programming as a whole and it has taken a long time to get the (mess) of code working that I have written.
I just cant picture how it could be structured, I was thinking you would set a variable to 0 then set to millis() and examine it each time through the loop, but the structure that I have currently got I don't think it could work?
Will this method work... I don't for a minute expect it to be the 'proper' way of doing it. I'm at work so won't be able to test anything until later this evening
I expect it will just stay in the while loop until the time has elapsed?
Thanks again
(the rest of the code is the same)
//Trigger focus
timer1 = millis();
digitalWrite(focusPin, HIGH);
while (millis() - timer1 > focusDelay)
//hold focus button down and do nothing else for x seconds
//Trigger shutter
timer1 = millis();
digitalWrite(shutterPin, HIGH);
digitalWrite(shutterLED, HIGH);
while (millis() - timer1 > (expose * 1000))
// Hold open shutter for x seconds
digitalWrite(shutterPin, LOW);
digitalWrite(shutterLED, LOW);
digitalWrite(focusPin, LOW);
cant get it to work It seems to enter the while loop, but does not execute its contents, and also does not exit the loop at all
what am I doing wrong here guys?
//Trigger focus
unsigned long timer1 = millis();
lcd.clear();
while (millis() - timer1 < focusDelay)
//hold focus button down and stay in this loop until focusDelay has been reached
lcd.setCursor(0,1);
lcd.print("test");
lcd.clear();
dtokez:
Unless the laws of physics have been repealed, that isn't possible.
That code will execute the loop zero or more times and then execute the code that follows. It has to either execute the body of the loop or leave the loop and execute the subsequent code.
What you've done there is just a hand-coded replacement for delay() that does the same thing - it blocks your sketch until the required time has passed. This in no way solves your problem.
Sorry I had the focusDelay to short to notice the while loop passing. It's working now and doing what I wanted, probably the entirely wrong way to do things but I'll continue to work on it!
Now it prints a countdown until the loop passes to the LCD which is what I was hoping to achieve
//Trigger focus
lcd.clear();
int countdown = 0;
lcd.setCursor(0,1);
lcd.print("test");
countdown = focusDelay - (millis() - timer1);
lcd.setCursor(1,0);
lcd.print(countdown / 1000);
lcd.print("s ");
Hello,
I'm not a programmer and totaly new to arduino, can somebody please point me to a site or eventually right here maybe, if I not ask to much, where I can get a copy of source code for time lapse? I have a DC motor that must be controlled and of course the camera. I can give more details if needed but I won't dare to ask more... Please help me, thank you in advance!
When it comes to switching things on and off you don't have too many options. You can turn it on and then delay but that has the problems the OP is finding out. It can't do anything else while waiting for delay. Another option is to use an interval timer. When you turn the device on get the time in millis, then just keep checking that the run duration hasn't been exceeded. basically if (millis() - onTime > runDuration) turn it off. You would probably want to use a similar scheme for when to turn it on next. Lastly, you can schedule on and off times, check against the current time and take appropriate action. To be effective this scheme needs a properly set clock.
I think what you are looking for is a 'simple scheduler', search for it in the forum. The simplest one is to put all the events you want in one loop. For every pass you check if the time is reached for the next event. See the 'blink without delay' example. Expand the example with several events, each with its own timer (previousmillis1, previousmillis2, etc.), if you need.
That's the level of complexity I manage myself so far, but you can do a lot with this. Only make sure one loop never takes longer than the minimum time base you have. It seems your events are hundreds of ms? Then you should be fine.
