time lapse dolly code problems
i have the limit switches wired from the 5v supply to digital pins 2 and 5 and i have 2 10k ohm resistors between pins 2, 5 and ground.
Toss the resistors. Connect one leg of a switch to ground. Connect the other leg to the digital pin. Turn on the internal pullup resistors.
pinMode(2, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
Then,
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
changes. Pressed is LOW.
Plus what AWOL said. There is no excuse for delay(), when the motor should just run the device back and forth.
