Time Libraries
I was wanting to use the time libraries But they don't play nice with arduino 1.0.1 or 1.0.0 And the Date time libraries has byte used in the serial part which keeps it from working.
Here what I get
sketch_nov11a.cpp: In function 'void loop()': sketch_nov11a:31: error: 'BYTE' was not declared in this scope
As of Arduino 1.0, the 'BYTE' keyword is no longer supported. Please use Serial.write() instead.
And here the Time sample
TimeSerial.cpp: In function 'time_t requestSync()': TimeSerial.pde:-1: error: 'BYTE' was not declared in this scope
replace BYTE with uint8_t in the libs
robtillaart: replace BYTE with uint8_t in the libs
Is the issue with the library or just with the example sketches? I've used the Time library with both 1.0.0 and 1.0.1, I don't think I remember having to do anything to the library itself.
Well I just looked at the libraries for Date Time and there casting byte to uint8_t so that shouldn't be a problem
And Yes I'm trying the sample for Timeserial so it may be just the sample.
Well just got done going over the file and this may be the cause of the problem
  Serial.print(TIME_REQUEST,BYTE);
  return 0; // the time will be sent later in response to serial mesg
That's the line that the compiler is telling you to change. It should be pretty simple to do so (at least with 1.0.2).
Ok it should be simple but there not any thing that shows how to handle a byte. Looks like it would be done this way
 Serial.write( TIME_HEADER);
Now for next problem
C:\Documents and Settings\Burt\My Documents\Downloads\arduino-1.0.2-windows\arduino-1.0.2\libraries\DateTime\DateTime.cpp: In member function 'void DateTimeClass::setTime(time_t)':
C:\Documents and Settings\Burt\My Documents\Downloads\arduino-1.0.2-windows\arduino-1.0.2\libraries\DateTime\DateTime.cpp:28: error: 'millis' was not declared in this scope
C:\Documents and Settings\Burt\My Documents\Downloads\arduino-1.0.2-windows\arduino-1.0.2\libraries\DateTime\DateTime.cpp: In member function 'time_t DateTimeClass::now()':
C:\Documents and Settings\Burt\My Documents\Downloads\arduino-1.0.2-windows\arduino-1.0.2\libraries\DateTime\DateTime.cpp:43: error: 'millis' was not declared in this scope
While I think I found that to just need to figure where to put this
time = millis(); to fix it
be80be: I was wanting to use the time libraries
Which time library(ies)? There are several. This one: http://www.arduino.cc/playground/Code/Time has no problems with Arduino 1.0.1.
