Time library help
Hey,
Need a little help. and am fairly new to Arduino. i am trying to use the Time library to make a simple sequence start at a predetermined time. in the full code i have found that all sides of an “if” statement are running . so i simplified to try and see what was happening. the below code is a test to see how the “if” statement is handling the library.
#include <Time.h>
int led = 13;
void setup(){
pinMode(led, OUTPUT);
void loop(){
if (second() <= 30){
digitalWrite(led, HIGH);
delay(100);
digitalWrite(led, LOW);
delay(100);
Serial.print(" ");
Serial.print(second());
What happens is i see my time increment in the serial monitor but my LED on Pin 13 is flashing to the delays. i was hopping to just turn the LED on when second() reset to 0 and off when second() reaches 30.
Any Help would be appreciated
Couple hints. (1) Do Tools > Auto Format, (2) Use code tags to post code.
Anyhoo, the two braces }{ alone on a line caught my eye. After auto format, it looks like below. Is maybe just an ELSE missing?
#include <Time.h>
int led = 13;
void setup(){
void loop(){
        delay(100);
        delay(100);
    Serial.print(" ");
Thx for the tip, and the quick response!
... yep that would do it... thx
