Time Library Serial examples won't complile
I’m trying to update time on the arduino using a processing sketch and an arduino sketch from: http://playground.arduino.cc/Code/time
Neither of them will compile, I think it’s because of newer versions not including files older ones did so I’d need yo write a few includes but not sure. Here are the sketches:
ARDUINO
 * TimeSerial.pde
 * example code illustrating Time library set through serial port messages.
 * Messages consist of the letter T followed by ten digit time (as seconds since Jan 1 1970)
 * you can send the text on the next line using Serial Monitor to set the clock to noon Jan 1 2010
 T1262347200
 * A Processing example sketch to automatically send the messages is inclided in the download
#include <Time.h>
#define TIME_MSG_LEN  11   // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER  'T'   // Header tag for serial time sync message
#define TIME_REQUEST  7    // ASCII bell character requests a time sync message
void setup()  {
  setSyncProvider( requestSync);  //set function to call when sync required
  Serial.println("Waiting for sync message");
void loop(){
  if(Serial.available() )
    processSyncMessage();
  if(timeStatus()!= timeNotSet)
    digitalWrite(13,timeStatus() == timeSet); // on if synced, off if needs refresh
    digitalClockDisplay();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
void processSyncMessage() {
  // if time sync available from serial port, update time and return true
  while(Serial.available() >=  TIME_MSG_LEN ){  // time message consists of a header and ten ascii digits
    char c = Serial.read() ;
    Serial.print(c);
    if( c == TIME_HEADER ) {
      time_t pctime = 0;
      for(int i=0; i < TIME_MSG_LEN -1; i++){
        c = Serial.read();
        if( c >= '0' && c <= '9'){
          pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
      setTime(pctime);   // Sync Arduino clock to the time received on the serial port
time_t requestSync()
  Serial.print(TIME_REQUEST,BYTE);
  return 0; // the time will be sent later in response to serial mesg
PROCESSING
 * SyncArduinoClock.
 * portIndex must be set to the port connected to the Arduino
 * The current time is sent in response to request message from Arduino
 * or by clicking the display window
 * The time message is 11 ASCII text characters; a header (the letter 'T')
 * followed by the ten digit system time (unix time)
import processing.serial.*;
public static final short portIndex = 1;  // select the com port, 0 is the first port
public static final char TIME_HEADER = 'T'; //header byte for arduino serial time message
public static final char TIME_REQUEST = 7;  // ASCII bell character
public static final char LF = 10;     // ASCII linefeed
public static final char CR = 13;     // ASCII linefeed
Serial myPort;     // Create object from Serial class
  size(200, 200);
  println(Serial.list());
  println(" Connecting to -> " + Serial.list()[portIndex]);
  myPort = new Serial(this,Serial.list()[portIndex], 9600);
void draw()
  if ( myPort.available() > 0) {  // If data is available,
    char val = char(myPort.read());         // read it and store it in val
    if(val == TIME_REQUEST){
       long t = getTimeNow();
       sendTimeMessage(TIME_HEADER, t);
       if(val == LF)
           ; //igonore
       else if(val == CR)
         println();
         print(val); // echo everying but time request
void mousePressed() {
  sendTimeMessage( TIME_HEADER, getTimeNow());
void sendTimeMessage(char header, long time) {
  String timeStr = String.valueOf(time);
  myPort.write(header);  // send header and time to arduino
  myPort.write(timeStr);
long getTimeNow(){
  // java time is in ms, we want secs
  GregorianCalendar cal = new GregorianCalendar();
  cal.setTime(new Date());
  int	tzo = cal.get(Calendar.ZONE_OFFSET);
  int	dst = cal.get(Calendar.DST_OFFSET);
  long now = (cal.getTimeInMillis() / 1000) ;
  now = now + (tzo/1000) + (dst/1000);
  return now;
What versions of Processing and Arduino are you using? What errors are you getting?
Arduino 1.0.3
time_t does not name a type
Processing 2.0b7
Cannot find a class or type named “GregorianCalendar” (in long get<timeNow())
You should not be using a Beta version of Processing. Use the 1.5.1 version.
The time_t type is defined in Time.h. If you installed the library in the right place, the example would compile.
Now Arduino 1.0.3
Still same, “Time” in <Time.h> stays the same color. (Windows 7)
(C:\Users\Ronald Porter Fox\Desktop\arduino-1.0.3\libraries\Time\Time)
And Processing 1.5.1
ArrayIndexOutOfBoundsExeption:1
Exception in thread “Animation Thread” java.lang.ArrayIndexOutOfBoundsException: 1
at SyncArduinoClock.setup(SyncArduinoClock.java:47)
at processing.core.PApplet.handleDraw(Unknown Source)
at processing.core.PApplet.run(Unknown Source)
at java.lang.Thread.run(Thread.java:662)
In what array? Most likely the array that is supposed to contain the list of serial ports that the Arduino might be connected to. Where is your output from the Processing sketch?
Arduino output:
TimeSerial:24: error: 'time_t' does not name a type
TimeSerial.pde: In function 'void setup()':
TimeSerial:20: error: 'requestSync' was not declared in this scope
TimeSerial:20: error: 'setSyncProvider' was not declared in this scope
TimeSerial.pde: In function 'void loop()':
TimeSerial:29: error: 'timeStatus' was not declared in this scope
TimeSerial:29: error: 'timeNotSet' was not declared in this scope
TimeSerial:31: error: 'timeSet' was not declared in this scope
TimeSerial.pde: In function 'void digitalClockDisplay()':
TimeSerial:39: error: 'hour' was not declared in this scope
TimeSerial:40: error: 'minute' was not declared in this scope
TimeSerial:41: error: 'second' was not declared in this scope
TimeSerial:43: error: 'day' was not declared in this scope
TimeSerial:45: error: 'month' was not declared in this scope
TimeSerial:47: error: 'year' was not declared in this scope
TimeSerial.pde: In function 'void processSyncMessage()':
TimeSerial:65: error: 'time_t' was not declared in this scope
TimeSerial:65: error: expected `;' before 'pctime'
TimeSerial:69: error: 'pctime' was not declared in this scope
TimeSerial:72: error: 'pctime' was not declared in this scope
TimeSerial:72: error: 'setTime' was not declared in this scope
TimeSerial.pde: At global scope:
TimeSerial:77: error: 'time_t' does not name a type
Processing output:
ArrayIndexOutOfBoundsExeption:1 Quote Exception in thread "Animation Thread" java.lang.ArrayIndexOutOfBoundsException: 1 at SyncArduinoClock.setup(SyncArduinoClock.java:47) at processing.core.PApplet.handleDraw(Unknown Source) at processing.core.PApplet.run(Unknown Source) at java.lang.Thread.run(Thread.java:662)
[/quote]
Is the Time.h file not in the right place?
TimeSerial.pde
Really?
TimeSerial.ino, still nothing.
