time - millis() problem
I was wondering why for the code below, orientTime doesn't work? When I run this code, my sensor will only execute the part where it printsXYZ data every 500ms, but it won't record the XValue every 3500 and 5000ms.
How should I format it correctly?
  case ORIENT: {
   xl.readXYZTData(XValue, YValue, ZValue, Temperature);
   orientTime = millis();
       if(millis() - orientTime >= 3500) {
           xvalt1 = (XValue);
           Serial.print("xvalt1=");
           Serial.println(xvalt1);
   if(millis() - orientTime >= 5000) {
           xvalt2 = (XValue);
           Serial.print("xvalt2=");
           Serial.println(xvalt2);
    if(millis() - lastPrintSample >= 500) {
       lastPrintSample = millis();
       Serial.print("X=");
           Serial.print(XValue);
           Serial.print("\t Y=");
           Serial.print(YValue);
           Serial.print("\t Z=");
           Serial.println(ZValue);
Post the complete sketch. Use code tags.
Nevermind, found that millis() - orientTime needed to be defined for each if-statement.
Why not do it once then use the result when you need it ?
           xvalt1 = (XValue);
           xvalt2 = (XValue);
Variables with the same name and a numeric suffix usually indicates that an array would be useful
I'm not sure how to properly format the code to do this.
I thought my code in the top post would have one timer running that can be accessed by each if-statement.
if (millis() - orientTime >= 3500) {
  xvalt1 = (XValue);
The condition in that 'if' statement will NEVER be true. Why won't you post the complete sketch?
You say that this
       Serial.print("X=");
works,
but that:
           xvalt1 = (XValue);
Does not.
Look carefully at both codes... what is different between them?
Jacques
Vitesze:
          xvalt1 = (XValue);
          xvalt2 = (XValue);
You are setting a variable to millis() and a few microseconds later checking to see if millis()-variable >= some large number. The millis() counter will not progress more than 1 in that short amount of time. You have to set the variable OUTSIDE the loop and not set it again until the time interval has expired.
Change
           xvalt1 = (XValue);
to
           xvalt1 = (XValue);
