time=millis()
Necesito ponerle a mi time=millis que apage luces cuando pase 5 minutos. yo puse if (time>5000){ digitalWrite(OutPinI, LOW); digitalWrite(OutPin, LOW); } else {digitalWrite(OutPinI, HIGH); digitalWrite(OutPin, LOW); } esta bien esto?
millis() gives milliseconds.
5000 is 5 seconds, not 5 minutes.
5 minutes is 5*1000*60=300000
sisi perdon. pero me dijo que le tengo que sumar la diferencia de lo que tarda oque vuelva el time=millis a 0 y eso es lo que no se hacer.
millis() gets the time.
You need to record the time when you want the 5 minutes to start, and then check the time in loop
unsigned long setTime;
     setTime=millis()+300000; //5 minutes
     //and everything else you need
      if (millis() > setTime)
//do stuff
//not time yet
setTime=millis()+300000UL; //5 minutes << add UL here
Is the “stuff” one time, or will it keep repeating?
// set up for next time if repeating
setTime = setTime + 3000000UL;
//do stuff
//not time yet, do other things (or, don't!)
} // end loop
