Hi, I am trying to get just the time using TINY RTC MODULE which uses ds1307 ic, with simple wiring and simple program let me give you details and time is not getting updated, once it initializes the system time the same is repeated again and again and doesn't get changed,
wiring,
tiny rtc SDA - Nano(A4)
tiny rtc SCL - Nano(A5)
tiny rtc GND - Nano(GND)
tiny rtc VCC - Nano(5V)
CODE `//DateTime (uint16_t year, uint8_t month, uint8_t day, uint8_t hour, uint8_t min, uint8_t sec)
//#include
#include "RTClib.h"
#define alarmPin 2
const int alarm[] = {2019, 6, 14, 22, 17, 0};
const int waitTime = 4000;
RTC_DS1307 rtc;
void setup () {
pinMode(alarmPin, OUTPUT); //set pin 2 as output
while (!Serial); // for Leonardo/Micro/Zero
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
rtc.adjust(DateTime(F(DATE), F(TIME)));
void loop () {
DateTime royal = rtc.now();
Serial.print("Time: ");
Serial.print(royal.year(), DEC);
Serial.print("-");
Serial.print(royal.month(), DEC);
Serial.print("-");
Serial.print(royal.day(), DEC);
Serial.print("-");
Serial.print(royal.hour(), DEC);
Serial.print("-");
Serial.print(royal.minute(), DEC);
Serial.print("-");
Serial.print(royal.second(), DEC);
AND THE OUTPUT I RECEIVE IS THIS
WHAT MIGHT BE THE ISSUE? CAN YOU PLEASE HELP ME?
