time on serial outputs
hi,
since two days, every time when I am printing with Serial.print() the actual time is printed at first and then the printout I want to print, eg.
Code for a Nano:
    Serial.begin(19200);
    while ( !Serial ) ;
loop()
v16=82;
v8=1;
lowbatt=0;
mspeed=76;
sprintf(outstr,"W%03dR%02dB%dM%03d",v16,v8,lowbatt, mspeed);
              Serial.println(outstr);
The expected result:
W082R01B0M076
the real result:
20:20:45.786 -> W082R01B0M076
Some days ago I played with a Teensy3.2, and varied the "Optimize" settings. I am not sure but I believe, after setting Optimize to debug, printig of the acutal time began.
Now back on the Nano which is using a different COM setting (COM 8 on Nano, COM 19 on Teensy) I always get the time at first on the printout, once every printed line.
The time comes from the PC (Win7) because the Nano and nothing in the environment has a rtc.
How can I switch off printing the time?
(deleted)
If you mean in the serial monitor on the Arduino IDE look at the bottom of the window on the left, there is a check box 'show timestamp', un-check it.
(deleted)
spycatcher2k:
It can’t be that! The OP would of tried that already before logging in to the site and typing up a question!
We shall see! Have you never made a mistake that you can’t find, only to find it and realise it was something really easy, which you should have seen straight away? I certainly have :o
hi,
it is so simple: you are right, there is a button "show time stamp". I never noticed it, and therefore was searching in the code and the configuration.
Thank you
It can’t be that!
It is so simple: you are right, there is a button “show time stamp”.
Ah… :slight_smile:
(deleted)
