Time out error? Arduino Nano (Temp Sensor)
Hi! Anyone could help with this?
I am getting what I think is a time out message on my nano in the serial data in Arduino IDE.
Any pointers would be cool!
I have 10k resistor on the data pin,
#include <Wire.h>
#include <DHTStable.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
DHTStable dht;
hd44780_I2Cexp lcd;
#define DHT11_PIN 2
const int LCD_COLS = 16;
const int LCD_Rows = 2;
int buttonState1 = 0;
const int But2 = 11;
int buttonState = 0;
const int But1 = 12;
byte termometru[8] = {
  B00100, B01010, B01010, B01110, B01110, B11111, B11111, B01110}; //chart for temperatura
byte picatura[8] = {
  B00100, B00100, B01010, B01010, B10001, B10001, B10001, B01110,}; //char for humidity
  DHTStable();
  lcd.begin(20, 4);
   Serial.println(__FILE__);
   Serial.print("LIBRARY VERSION: ");
   Serial.println(DHTSTABLE_LIB_VERSION);
   Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)\tTime (us)");
void display()
  lcd.write(1);
  lcd.setCursor(0, 1);
  lcd.print(dht.getTemperature());
  lcd.print(" ");
  lcd.print((char)223);
  lcd.print("C");
  lcd.setCursor(10, 1);
  lcd.write(2);
  lcd.print(dht.getHumidity());
  lcd.print(" ");
  lcd.print("%");
void buton()
  buttonState = digitalRead(But1);
  delay(10);
  if (buttonState == HIGH)
    lcd.backlight();
  else {
    lcd.noBacklight();
  int chk = dht.read11(DHT11_PIN);
  delay(2000);
  buton();
  Serial.print("T: ");
  Serial.println(dht.getTemperature());
  Serial.print("H: ");
  Serial.println(dht.getHumidity());
and the error message;
Type, status, Humidity (%), Temperature (C)
DHT11, Time out error, -999.0, -999.0
Seems the library tells you it did not get data from the DHT11
In the library example they handle this by doing
int chk = DHT.read11(DHT11_PIN);
  switch (chk)
    case DHTLIB_OK:
      Serial.print("OK,\t");
    case DHTLIB_ERROR_CHECKSUM:
      Serial.print("Checksum error,\t");
    case DHTLIB_ERROR_TIMEOUT:
      Serial.print("Time out error,\t");
    default:
      Serial.print("Unknown error,\t");
Hi thanks, its strange because I use the library and it doesn't work either. hm.
can you share a link to your DHT11 module?
did you wire your DHT correctly? good cables? how long?
has this DHT11 ever worked?
yep - its from Botland.pl(I live in PL) Czujnik temperatury i wilgotności DHT11 - moduł + przewody Sklep Botland into Arduino Nano, and im unsure if its ever worked, I have 2 sensors, both new (1 straight out of packaging just now) cables are 5/6 or so hookup wires. - Arduino Nano took a while to get going but all working now.
I attached photos, apologies my camera isn't so good. On the sensor its + out. Red is +, grey is out(data) and orange is -
Hey - no worries I fixed it. My pinouts were a mess :stuck_out_tongue: thanks!
:crazy_face:LOL - we have all been there
