Time out error while uploading sketch for blink example in Arduino Mega 2560
I just start using Arudino Mega 2560 board. I started with Blink example. The issue I am facing is that when I compile the Blink example it just work fine but when I try to upload the sketch it gives me a time out error. I have checked my port and board id I have choose them correctly. I try both of the programmers from the tools AVRISP and AVRISP mk II. Following is the error that I receive
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x10
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: ser_send(): write error: sorry no info avail
. Kindly guide me how to solve it. Regards
Ok I got the solution. I forget to install rxtxSerial-2.2_fixed_2009-03-17. After I add this BINGO the code start working just fine. Just sharing it so that other people get benefit from it to.
