Hello, I have a doubt that is:
Through a signal generator inject a syn wave (2pi * f) at pin A0 Arduino.
0 1 2 4 6 7 8
My point is that the Arduino reads the values of the sinusoid but that time?
The value 2 corresponds to the time instant? do not know!
How do I know the value that each time corresponding amplitude read by Arduino?
ricperes:
0 1 2 4 6 7 8
what is the voltage range of the sin wave 0..5v? IF so then an equation that replicates this would be
v=sin(angle)*2.5+2.5
sin(angle)=(v-2.5)/2.5
angle = asin((v-2.5)/2.5)
So angle is between -pi/2 and pi/2 the only way to identify quadrant 2 or quadrant 3 values is by inspection. if you know the sine wave is flowing 0, pi/2, pi, 3pi/2, 2pi you could compare current value of angle to prior value. If prior value was in quadrant 1, and angle was decreasing then angle = pi -angle.
if prior value was in quadrant 2 and and angle < 0 then angle = pi - angle. if
#include <Math.h>
static double prior=0;
/* this function only works if called with voltage values faster than f*4 */
double getPhaseAngle( double voltage){ // 0.. 2pi
double angle=asin((voltage-2.5)/2.5);
if(angle>0){
if(angle>=prior){// still quadrant 1
raw=angle;
quadrant = 1;
prior=angle;
else { // quadrant 2
raw=angle;
quadrant = 2;
prior=angle;
angle = pi - angle;
else {
if(angle<=prior) { //
raw=angle;
quadrant = 3;
prior = angle;
angle = pi - angle; // minus a negative equals a plus
else {// moving through quadrant 4
raw=angle;
quadrant = 4;
prior = angle;
angle = 2*pi + angle;
return angle;
chuck.
chucktodd:
#include <Math.h>
if(angle>0){
raw=angle;
quadrant = 1;
prior=angle;
raw=angle;
quadrant = 2;
prior=angle;
angle = pi - angle;
else {
raw=angle;
quadrant = 3;
prior = angle;
raw=angle;
quadrant = 4;
prior = angle;
return angle;
chuck.
Yes, i Sum 2.5V DC because arduino don't read negative values.
Sorry , my doubts but, i don't understand , i want to read a sinusoidal wave, and know like this:
For example:
Read : 2 0.000001 s
Read: 3 0.000002 s
I want to know the time that arduino read value, because arduino do it automatically.
ricperes:
For example:
Read : 2 0.000001 s
Read: 3 0.000002 s
The arduino has a free running timer millis() that counts milliseconds in a unsigned long value
so if you use this code:
unsigned long sampleTime = millis();
unsigned long t;
unsigned int sampleVoltage = analogRead(A0);
//Serial.print("Voltage=");
Serial.print(float(sampleVoltage)*5.0/1024.0,2);
/* uncomment this section to have full time since boot displayed
Serial.print(" day=");
Serial.print(sampleTime/(1000L*60*60*24));
sampleTime %=(1000L*60*60*24);
Serial.print(" time=");
t= sampleTime/(1000L*60*60);
if(t<10)Serial.print('0');
Serial.print(t);
Serial.print(":");
sampleTime %=(1000L*60*60);
t= sampleTime/(1000L*60);
Serial.print(t);
sampleTime %=(1000L*60);
Serial.print(":");
t= sampleTime/(1000L);
Serial.print(t);
sampleTime %=1000;
t=sampleTime;
t= sampleTime % (1000L);
Serial.print(" .");
if(t<10)Serial.print("00");
else if(t<100) Serial.print("0");
Serial.println(t);
Chuck
It takes the Arduino about 0.1mS for the Arduino not the 1uS in your example.
While you can take a time stamp of when your reading it will not be synchronised to your waveform. You can only synchronise it by referencing it to something like a zero crossing which is best done by using a comparator to generate an interrupt. Then have the interrupt service routine capture the millis time as a referance.
What is it that you want to do?
Measure the period / frequency of the sinewave?
Measure the amplitude of the sinewave?
Tom...
TomGeorge:
Tom...
Hello Tom, I measure a amplitude of the sinewave but i want to know in that this measuring time is made.
Do you undestand me?
thanks
Well if I have not given you the answer then no I don't understand you.
Do you want to know the time BETWEEN samples?
OR do you want to know the period/frequency of the sinewave?
WHICH ONE or NIETHER?
What is the application of your sketch, what is the final function of your project?
Tom...
TomGeorge:
Tom...
this is for a project, eletronic and programming also.
I want to know the time between samples,ie the time instant that each amplitude value corresponds,
not the time it takes to make a reading.
What is wrong with answer #4?
Do you not understand it?
If so ask.
Grumpy_Mike:
If so ask.
Sorry , I don't understand, can you show me a code to explain me that please?
thanks
No the way this forum works is you write the code and we can help you with it. I have already told you what the code should be, so you have a go at writing it. Then test it and post your code and the results.
ricperes:
ok, thanks anyway
Please do my homework for me.
chuck.
