Time stamps
I have to send a 2 byte time stamp via serial to my computer.
This will consist of how many milliseconds since the arduino started.
This time stamp needs will roll over every 65 seconds and that's fine. However I don't know how to generate it.
Should I use millis() ?
I don't know how to truncate the least significant 2 bytes and separate them into individual bytes.
Also, is this even possible with millis() accuracy?
Should I just count time0 ?
How could I keep track of every roll over while still running the rest of my code?
Thank you, any comments are greatly appreciated.
Yes.
You don't need to. The compiler will do it for you.
Yes.
No need.
Just cast the return value from millis to "unsigned short"...
void loop( void )
Serial.print( (unsigned short) millis(), DEC );
Thank you that was extremely helpful.
I added the & 0xFFFF to get the least significant 16 bits.
Serial.print( (((unsigned short) millis()) & 0xFFFF), HEX );
Is there a way to get ride of the least significant 8 bits, so I am only printing 1 byte?
legoEngineer2011:
That wasn't necessary but a bitwise-and will help with the next request...
(millis() >> 8) & 0xFF
