I am trying to Build time Switch application For ATM machine. I am dividing 24 hours into 2 interval . 12 hours to run 2 Set of AC and other 12 hours by other AC.
Timing Has to be set by user.
I am using ardunio uno, lcd sheild ,and DS1307 for testing trial.
User can set time externally through LCD keypad sheild , as per Set time and working hours Device should get on.
I try to build using timealaram library But can't set define Time externally.
ATM ? Automatic Teller Machine ?
Except for a very early prototype to test some functionality, an Arduino would not be considered robust enough for such a role. And what is an AC in this context ?
Anyway, some things to consider:
Automatic update for daylight saving time
For setting the switch times, a library is maybe overkill. Simply compare the current time HH:MM with the stored switch (ON/OFF) time.
A DS3231 is a much better real time clock than DS1307 and is generally compatible (libraries etc.)
