Seems to me you have that figured out. Send each Arduino the time, from the one that knows the time. Have the other Arduinos parse the time string, and set the time appropriately.
Essentially, from the UNO that has the DS1307 (etc.) attached, send the other UNOs the variables over some communication path. They are all numeric, so you could just send them as ASCII values and convert after receiving.
Remember to design the sketches on your 'slave' Arduinos to support the type of date/time adjustments that your clock sync mechanism will perform. For example, making step adjustments (just setting the clock to the correct time) is easiest to implement but means your sketch must deal with time making arbitrary jumps backwards and forwards. Skew adjustments are easier for the sketch to deal with but harder to implement. The sketch would need to be coded to work correctly too (you can no longer assume that the difference between two wallclock times is the same as the difference between two readings of millis()).
An absolutely critical statement and "on steroids" IF logging to an SD card is implemented... Downstream analysis of the logs rarely are written to permit timestamp discrepancies... That is, out-of-order sequencing.
Another way to sync is to provide a pulse from the master clock every (milli)second which is received by the slaves in an interrupt.
Furthermore, it might be easier/faster to send the time as a binary number (seconds since 2000) as that would take less time to communicate and the receiving slave can decode that quite fast.
You might want to consider if you need to handle daylight saving time. If you do then once a year you will have a gap of an hour, and once a year an hour will happen twice. Much better to avoid daylight saving if you can.
I love Unix timestamps. Internally, all you deal with is the number of seconds since the Epoch in GMT and no mucking about with timezones or DST. All you have to keep track of is one simple unsigned long rather than a messy array of year, month, day, hour, minute, second. This means that doing things like calculating differences or offsets is stupid simple arithmetic. For example, want something to happen 24 hours from now? = epoch + (60 * 60 * 24).
Then you just have a couple little functions to convert to/from Gregorian strictly for human interface.
tylernt:
Though potentially you would have a problem with things like leap seconds.
Also, multi-core implementations can have problems since the internal clock each core keeps may not be synchronized across all of the cores in the chip, let alone multiple chips that together constitute the computer.
That's a common representation of a wallclock time, and there are plenty of other similar formats that have the same characteristics. However you represent it, you still have to deal with the fact that wallclock time is not the same as real time and can speed up, slow down, jump backwards and forwards.
