Ok, so after weeks of reading, researching and prototyping I finally have a working model for my project which is to drive individual RGB strips in my new custom designed staircase. Each tread has a frosted glass insert and niche for a RGB strip. I'll be controlling each step individually through sensors and other fun stuff, but for now I'm sticking to the basics, cycling through some PWD code. I've prototyped using single RBG LEDs but before I hook everything up, I'd like someone to check my calculations so that I don't blow up my chips. So here's the setup:
3 TLC5940s daisy-chained per instructions found in the playground. Based on the strip specs, I would need a 12V 3.6A power source to drive the strips on full load (white). I'd also like to have a single power source for the strips and the arduino. Will the approach below work? I've read a little about de-coupling to keep the TLCs from over-heating. Is that something I need to consider here? Any help in getting this right the first-time without casualities would be appreciated ![]()
On a related programming note, any best practices around connect the PWM channels? is it easier to write logic connecting the RBGs like this or having all the Blues to one TLC, Reds to another, etc...? Thanks again
