Time to two digit value
Hello!
I made a temperature logger which logs the temperature along with time/date from RTC module. But when the hour or minute or second is one digit, it does not show the zero in front.
For example:
13:4:0
But I would like to see:
13:04:00
The code that I am using
DateTime now = rtc.now();
myfile = SD.open(filename, FILE_WRITE);
myfile.print(now.hour(), DEC);
myfile.print(":");
myfile.print(now.minute(), DEC);
myfile.print(":");
myfile.print(now.second(), DEC);
Can someone help me how to accomplish this?
see here:
I might also add that it may be the library you are using to read the RTC. I haven't worked with RTC's in a while, but i do not remember this being an issue when I was...
... of course, I was not "printing" the values from the RTC, I was building "unique" servo and stepper motor clocks and I was just getting values from my RTC, so the "digit format" would not have really mattered to me...
if (now.hour() < 10)
  myfile.print('0');
myfile.print(":");
if (now.minute() < 10)
  myfile.print('0');
myfile.print(":");
if (now.second() < 10)
  myfile.print('0');
Thank you!
