time variable?
basically i have a bit of code that states the LED will be on when the RFID tag is within range, but i need a piece of code that states that if it is out of range for 1/2 seconds it will turn off?
At the moment then the LED flashes off every time the rfid module refreshes the scan so i want it to wait for roughly 1/2 seconds before it turns off?
i need it between the while and if command:
while(rfid.available()>0){
    c=rfid.read();
    msg += c;
    Serial.println(msg);
    Serial.println(msg.length());
    digitalWrite(8,HIGH);
  if(rfid.available()==0){
    c=rfid.read();
    digitalWrite(8,LOW);
This is the entire code if that makes it any easier for people?
#include <SoftwareSerial.h>
#define ADD_TAG_CODE "0001361049"  //change this ID with your own card TAG
#define DEL_TAG_CODE "0000946210"  //change this ID with your own card TAG
SoftwareSerial rfid = SoftwareSerial(5,6);
String msg;
String ID ;  //string to store allowed cards
  Serial.println("Serial Ready");
  rfid.begin(9600);
  Serial.println("RFID Ready");
  pinMode(8,OUTPUT);
char c;
void loop(){
digitalWrite(5,LOW);
digitalWrite(6,LOW);
delay(1);
digitalWrite(5,HIGH);
digitalWrite(6,HIGH);
if(Serial.available())
while(Serial.available())
Serial.write(Serial.read());
    c=rfid.read();
    msg += c;
    c=rfid.read();
Try this (untested).
    c=rfid.read();
    msg += c;
    ledOnTime = millis();  // record when led turned on
  if(rfid.available()==0 && (millis() - ledOnTime >= 500) ){  // check for no data and 0.5 seconds elapsed
    c=rfid.read();                                                        // why read if nothing is there?
Pins default to input. Here all you are doing is turning the internal pullup resistors off and on.
delay(1);
