Hi
How to convert time_t value to normal date (DD-MM-YY) ?
My another question is does the arduino IDE clear eeprom on every sketch upload?
Hi
I can answer that one. No. The EEPROM is not modified by uploading.
mm It's strange because when I'm reading eeprom after uploading a sketch it is full of 255 values
I'm using usbasp to upload sketches maybe that is why its happening ?
I assumed you were using the bootloader. I have no idea if using usbasp to upload will result in the EEPROM being erased.
255 is returned when a cell has been erased. This is the way the processor comes from the factory.
Whatever you find out about the usbasp and EEPROM, please report back. It's very likely someone else will value your experience.
#include <Time.h>
tmElements_t tempTimeStruct = {
55, 59, 23, 6, 19, 3, 40};
time_t arduinoTime = 0;
arduinoTime = makeTime(tempTimeStruct);
setTime(arduinoTime);
makeDateTimeString();
void makeDateTimeString(){
char tempBuff[5];
char tempString[16];
byte tempByte = 0;
strcpy(tempString, "");
// Days
tempByte = day();
if (tempByte < 10 ) strcat(tempString,"0");
itoa(tempByte, tempBuff, DEC);
strcat(tempString, tempBuff);
strcat(tempString, "-");
// Months
tempByte = month();
if (tempByte < 10 ) strcat(tempString, "0");
// Years
tempByte = year()-2000;
strcat(tempString, " ");
// Hours
tempByte = hour();
strcat(tempString, ":");
// Minutes
tempByte = minute();
strcat(tempString, ".");
// Seconds
tempByte = second();
Serial.println(tempString);
Thank you but your code is not very redable
I rewrote my code to use time.h instead of DateTime.h
Time.h has ready to use day(time_t) etc
sounds like you already have it going, but for the benefit of others, you can do this assuming you include <Time.h> and t is a time_t value:
Serial.print(day(t));
Serial.print('-');
Serial.print(month(t));
Serial.print('-');
Serial.println(year(t));
