TimeAlarms and digitalWrite
Hello,
I am new in programming Arduino and I can`t find a solution for this Problem. I hope you can help me!
I want control extrenal devices via a Realis at a specifik time. To get the correct time I use the eathernet schield. This works fine.
The Problem is, that the digitalWrite doesn´t work.
Here is the code:
#include <TimeAlarms.h>
#include <Time.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
//Ethernet Shield Settings
              byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x0F, 0xD0 }; // Mac Adresse des Ethernet Shields
              unsigned int localPort = 8888;          // local port to listen for UDP packets
              IPAddress timeServer(192, 43, 244, 18); // time.nist.gov NTP server
              const int NTP_PACKET_SIZE= 48;          // NTP time stamp is in the first 48 bytes of the message
              byte packetBuffer[ NTP_PACKET_SIZE];    // buffer to hold incoming and outgoing packets
              EthernetUDP Udp;                        // A UDP instance to let us send and receive packets over UDP
//Programm Settings
              int NestAufPin = 13;                    // Nest-Auf auf PIN 13 legen
              int NestZuPin = 12;
              int t = 3000;                           // Impulsdauer
              int T = 6000;                           // Periodendauer
              long Zeitstempel = 0;                   // Zeitstempel für Delay
              int ledState = LOW;                     // Initial kein Strom
  // Alarm Settings
        Alarm.alarmRepeat(5,0,0,NestAuf);         // Nest auf um 5:00 Uhr
        Alarm.alarmRepeat(21,0,0,NestZu);          // Nest schließen um 21:00 Uhr
        Alarm.timerRepeat(5, Repeats);
  // start Ethernet and UDP
        if (Ethernet.begin(mac) == 0) {
          Serial.println("Failed to configure Ethernet using DHCP");
          // no point in carrying on, so do nothing forevermore:
          for(;;);
        Udp.begin(localPort);
  ZeitSync();
  pinMode(NestAufPin, OUTPUT);
  pinMode(NestZuPin, OUTPUT);
  digitalWrite(NestAufPin, ledState);
  digitalWrite(NestZuPin, ledState);
void  loop(){
  if (millis() - Zeitstempel > 1000){        // eine Sekunde warten vor der aktualisierung der Zeit ohne D
    Alarm.delay(0);
    Zeitstempel = millis();
    digitalClockDisplay();
void ZeitSync(){
  Serial.println("Zeit sync");
  sendNTPpacket(timeServer);                 // send an NTP packet to a time server
  delay(1000);                               // wait to see if a reply is available
  if ( Udp.parsePacket() ) {                 // We've received a packet, read the data from it
    Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);  // the timestamp starts at byte 40 of the received packet and is four bytes, or two words, long. First, esxtract the two words:
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    // combine the four bytes (two words) into a long integer
    // this is NTP time (seconds since Jan 1 1900):
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    const unsigned long seventyYears = 2208988800UL;
    unsigned long epoch = secsSince1900 - seventyYears;
    unsigned long std = ((epoch  % 86400L) / 3600) + 1;    // UTC Zeit + 1 = Winterzeit
    unsigned long minu = ((epoch  % 3600) / 60);
    unsigned long sek = (epoch %60);
    setTime(std,minu,sek,1,1,11);
void NestAuf(){
  Serial.println("Nest auf");
  digitalWrite(NestAufPin, HIGH);
  digitalWrite(NestZuPin, LOW);
void NestZu(){
  Serial.println("Nest schließen");
  digitalWrite(NestAufPin, LOW);
  for(int i = 0; i < 10; i++) {
    digitalWrite(NestZuPin, HIGH);
    delay(t);
    delay(T - t);
void Repeats(){
  Serial.println("15 second timer");
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
  Serial.println(ledState);
void digitalClockDisplay()    // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
void printDigits(int digits)
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address)
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
To see if the TimeEvent works there is the "Repeats" function.
Here is the result:
Zeit sync
15 second timer
1
20:23:01
20:23:02
20:23:03
20:23:04
20:23:05
15 second timer
0
20:23:06
20:23:07
20:23:08
20:23:09
20:23:10
15 second timer
1
20:23:11
20:23:12
20:23:13
20:23:14
20:23:15
15 second timer
0
20:23:16
20:23:17
20:23:18
20:23:19
20:23:20
15 second timer
1
20:23:21
20:23:22
20:23:23
You can see, that the event works fine, but the "NestAufPin 13" doesn´t change the voltage. I can not unterstand why?
If I test the board with the "blink"-Example everything works fine.
I use the Arduino 1.0.1 and the sketch use 16.924 Bytes.
Many thanks for your help!
I can't spot any problem in the code. As far as I can see, the sketch will toggle pin 13 high and low every time it prints "15 second timer", and there is nothing else that would change the state of pin 13 without also producing trace messages.
What is connected to pin 13? Is there any external hardware that would pull it up or down? Does your Ethernet shield make any use of pin 13?
Hello,
many thanks for your answers!
Delta_G, you are right. I have tried PIN 1, but it doesn`t work too. PIN 2 and 3 works fine! :slight_smile:
Is that the same pin 1 used by the serial interface?
