TimeAlarms.h works for a few days and quits
Hi everyone,
I have some code below that uses TimeAlarms.h and an Adafruit RTC 1307 on an Uno to run a stepper motor to open and close a door at 6:00am and 6:30pm. The whole process was working great for weeks but then the was power shut off and since then the process has been working for a few cycles and then it fails and the door remains open.
Things I can confirm:
  • power is not being interrupted because Arduino is on when the alarm should run
  • the RTC is maintaining correct time. When I disconnect the Aruduino from its power supply and plug it into my computer to check the time on the serial monitor the time is correct. I am not recompiling the code, I’m simply checking the time
  • the door itself is working fine. I can push the open/close button (runs on pin 11) and the stepper runs and opens and closes the door
I really don’t think I changed anything on the code but I wanted to see if you all could see if I’m missing something. Thank you for any help!
// Coop Door running on Real-time clock.
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include <Time.h>
#include <TimeAlarms.h>
#include "RTClib.h"
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Connect one stepper w/xxx steps to the bottom shield
Adafruit_StepperMotor *myMotor = AFMS.getStepper(2048, 1);
RTC_DS1307 RTC;
unsigned long DoorStatus = 0;     // 0 = open, 1 = closed
int LimitPin = 10;  // Limit switch
int ButtonPin = 11;  // Button
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
time_t syncProvider()     //
  return RTC.now().unixtime();
  pinMode(A3, OUTPUT);    // set up pullup resistor for ground
  digitalWrite(A3, HIGH);    // turn on pullup resistor for ground
  pinMode(A2, OUTPUT);    // set up power for RTC
  digitalWrite(A2, LOW);    // turn on RTC
  pinMode(LimitPin, INPUT);    // limit as input
  digitalWrite(LimitPin, HIGH); // turns on pull-up resistor after input
  pinMode(ButtonPin, INPUT);    // button as input
  digitalWrite(ButtonPin, HIGH); // turns on pull-up resistor after input
  Wire.begin();
  RTC.begin();
  //  setTime(8,29,0,1,1,11); // set time to Saturday 8:29:00am Jan 1 2011
  // create the alarms
    if (! RTC.isrunning()) {
      Serial.println("RTC is NOT running!");
//   following line sets the RTC to the date & time this sketch was compiled
  RTC.adjust(DateTime(__DATE__, __TIME__));
  setSyncProvider(syncProvider);
  AFMS.begin();  // create with the default frequency 1.6KHz
  myMotor->setSpeed(6);  // 10 rpm
  Alarm.alarmRepeat(6, 00, 0, OpenDoor); // 6:00am every day
  Alarm.alarmRepeat(18, 30, 0, CloseDoor); // 6:30pm every day
  DateTime now = RTC.now();
  Serial.print("Coop Door with Real-time Clock");
  Serial.print(year(), DEC);
  Serial.print('/');
  Serial.print(month(), DEC);
  Serial.print('/');
  Serial.print(day(), DEC);
  Serial.print(" (");
  Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
  Serial.print(") ");
  Serial.print(hour(), DEC);
  Serial.print(':');
  Serial.print(minute(), DEC);
  Serial.print(':');
  Serial.print(second(), DEC);
void  loop() {
  Alarm.delay(1); // mandatory check on the alarm/time status
  // CLOSE door if BUTTON is pushed and door is OPEN
  if (digitalRead(ButtonPin) == LOW && DoorStatus == 0) {
      while (digitalRead(LimitPin) == HIGH)  // when pin goes HIGH/Switch is open
        myMotor->step(1, BACKWARD, SINGLE); //run the stepper
    myMotor->release(); //power down the stepper
    DoorStatus = 1; // Door is CLOSED
  // OPEN door if BUTTON is pushed and door is CLOSED
  if (digitalRead(ButtonPin) == LOW && DoorStatus == 1) {
    myMotor->step(8000, FORWARD, SINGLE); //run the stepper
    DoorStatus = 0; // Door is OPEN
void OpenDoor() {
  if (DoorStatus == 1)
void CloseDoor() {
  if (DoorStatus == 0) {
Not your bug but
unsigned long DoorStatus = 0;    // 0 = open, 1 = closedis a lot of memory for a boolean type...
Your pins variables should be better off as const byte rather than int
daysOfTheWeek is overusing memory when you could declare it as const char * daysOfTheWeek[] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
Besides that, Can you explain what you have on A2 and A3 and what your code in setup() is supposed to do?
This probably should be commented out RTC.adjust(DateTime(__DATE__, __TIME__)); if your arduino reboots you'll set the wrong date in your clock
Which RTC you've got and how it is wired also interests me. I guess it has a battery backup so explicit control of the power to it (as you appear to be using) should be unnecessary.
Thanks JML. I will review those efficiencies and test them out on the next round.
A2 and A3 are providing power to the RTC to run when connected to the Uno. When A3 is high it is grounded on pullup resistor. When A2 is low it provides voltage to the 1307 RTC.
The other pin setups are for a limit switch to let the stepper know when the door is closed and a button that allows me to manually open the door.
I think the following is where I'm having my issues:
This probably should be commented out RTC.adjust(DateTime(DATE, TIME)); if your arduino reboots you'll set the wrong date in your clock
I am going to comment it out and see if that fixes it. I feel like I might have done that in the past when it was working well and maybe I took off the comments thinking that the RTC.adjust would only run if RTC was not running per the if statement part of the code:
What's strange is I compiled the code and confirmed the time on the serial monitor. I powered down the Uno for a few minutes, plugged it back into the serial monitor and the time was fine. Is there something that would make this work for a few hours but then after a few days it would fail?
6v6gt
I am using this RTC: https://www.adafruit.com/product/264
Since you have an RTC, the TimeAlarm library is not really necessary. On every pass through loop(), get the current time. See if it is time to open the door. If it is, open the door. See if it is time to close the door. If it is, close the door.
Thanks, PaulS.
One thing I'm trying to understand is why the alarm works a few times and then quits. When I do a time check on the serial monitor my RTC is accurate. My code had been working successfully for months and then it stopped working. I'm afraid I accidentally changed something in the setup that is causing the issue. The setup code is very basic but I can't tell if something is amiss. Is there anything you notice that would cause an issue? Again, code was working fine for months, now it's not. Thanks again.
Is there anything you notice that would cause an issue? Again, code was working fine for months, now it’s not.
First, I would check that the limit switch on pin 10 is not sticking closed and giving a LOW.
Second, I would use the pin 13 led indicator in the alarm function to see if you are entering or not entering the function. If the door fails open with the led lit, you know the problem is not anything to do with the time and the alarms.
void CloseDoor() {
   digitalWrite(13, HIGH);//declare pin 13 as an output in setup
Cattledog, thanks for the helpful response. Sorry for the delay in responding, I've been running the code for the last several days to test.
I commented out the RTC.adjust and the door opened and closed every day for 3 days with no issue. Then, the door stopped closing at night but would still open in the morning. Again, the door would open and close when I manually pushed the button, just for some reason it stopped closing. I would close it at night for a few days but it would still open in the morning no problem. Then, it wouldn't open or close. Again, the door would open manually with the button but it wouldn't work with the timer.
I'm going to add Cattledog's troubleshooting suggestion with pin 13 to let me know if the alarm triggers. I feel like it has something to do with how the RTC talks to the Arduino and somehow the connection gets lost or scrambled and the system loses track of time. In the past when the alarm stopped working I tested the time on the RTC in the serial monitor and it was still accurate.
Does anyone have any insights on how the RTC 1307 interacts with the Arduino and how communication might get dropped or scrambled?
PS - I will follow up with the pin 13 test in the next several days.
setSyncProvider() coordinates the internal millis() clock with the real time clock. When the program starts, the time library will reference the millis() clock to the rtc time. Instead of millis() marking the time since the program started, the time library will use millis() to add to the time since the time on the rtc when the program started.
Then, every five minutes(the default synchronization period), the Arduino (time library) will get the time from the rtc, and if the millis() based time is different, it adjusts the millis() based time to match, thus keeping in synch.
All this is managed in the background by the time library.
If the time within the RTC is correct, but the reading of the RTC was scrambled and the arduino looses track of time on one reading, it should be corrected 5 minutes later.
If the led indicator experiment doesn’t get you focused on something other than the time, you can use an SD card module to log the time.
Do you have an SD module and card you can use?
If you don’t, they are very inexpensive (costs way less than a chicken :slight_smile: ), and pretty easy to use. If you get one, make sure it has the level shifter IC, and not the resistance network. The Catalex module for a micro sd card is good if there is only one device using SPI.
Cattledog,
Thanks for all the suggestions. Here's what I have so far:
  • I added the 13 pin test to the alarm and the alarm triggered the pin along with the stepper motor.
  • The alarm never triggered the pin without running the stepper motor.
  • When I checked the RTC it was still accurate and reporting the correct time.
I tested several scenarios to see if something with the alarm or RTC might be wrong:
  • I set an alarm for less than 5 minutes out and the alarm worked as expected
  • I set an alarm for 15 minutes out and the alarm worked as expected
  • I set an alarm for 5 minutes out, removed and reconnected the RTC while the Arduino was running, and the alarm worked as expected
I was finally able to have the alarm fail when I stumbled across something I had not noticed before. I noticed that when I connect power to the Arduino, I don't always make a solid connection and sometimes the Arduino power light will turn off and on as I get the power connected. The reason is that I have a stepdown that takes the power from 12v to 5.2v and it isn't always easy to get the wires into the stepdown in a smooth, solid way. I always ended up with solid 5.2v power with plenty of amps behind it but the way that I connected the power seems to be a problem. I believe this is what was causing my issue.
When I made a poor initial power connection the alarm would fail. I would reset and make a solid initial power connection and everything worked fine. I setup the Arduino to run the door and made sure to make a solid initial connection. The door has worked fine for one of the alarms so far. I will keep you posted on whether this solves the problem long term.
I'm also wondering if this scenario could cause one alarm to fail before the other alarm does. Last time I had an alarm failure, the nightly alarm failed for a few days while the morning alarm worked fine. Then, the morning alarm finally failed. I don't know what goes on behind the scenes in these multiple time libraries but I'm wondering if the faulty initial connection could cause the issue.
PS - thanks to PaulS for the suggestion to remove the whole alarm function to begin with. I understand the concept and appreciate the simplicity. I just haven't taken the time to test and implement.
Well, the second alarm did not work today. The morning alarm worked fine. I tested the evening alarm yesterday night under all the various circumstances listed above and it worked without issue except when I purposely caused a poor initial power connection. This time I made a solid connection so that should not be the issue.
Why would the morning alarm work but the evening alarm does not? The only guess I can make is the passage of time and some issue between the RTC and Arduino but the RTC checks out.
Or, there is some conflict between the various time libraries that causes intermittent issues. What’s strange is the code worked for months until my primary battery died. Now it doesn’t work and I didn’t make any changes…
#include <Wire.h>
#include <Time.h>
#include "RTClib.h"
If anyone has any pointers on this I would greatly appreciate it. I am also going to try and write a sketch that only uses RTClib.h instead of all the other time libraries.
What did the led test tell you? Did the program enter the alarm function but did not close the door?
You have to set up the led tell tale so that if the door opens or closes properly the led is turned off, and can indicate the failure mode on the next alarm action.
The test told me that the alarm did not trigger. I have it set so that the LED turns on when the alarm triggers. When the door did not close the LED did not turn on. Strangely, the morning alarm has triggered and opened the door fine the last two days.
The open/close functions both use Alarm.alarmRepeat and simply run different but very similar pieces of code.
void OpenDoor() {
void CloseDoor() {
Why would one alarm work and the other does not work when they use the same function to run?
It really makes me think there is some time glitch occurring at night that doesn't occur in the morning. At night, I can push the manual and the door closes, so I know it's not the door. And, as mentioned above, the test LED does not come on when the alarm is supposed to run so I know the alarm didn't run.
Thanks for any further advice!
Excellent! You have indeed confirmed that the problem is with the time keeping.
One possibility is that when the system clock is running slow to the real world, and is updated with synchronization, it advances beyond the alarm time. The alarm will not trigger until the next cycle. It does not recognize that it is overdue.
Here's a suggestion, if your RTC is reasonably accurate, you may be able to synchronize once per day, at a time well away from any alarm.
Add this line to the sketch to create a once per day sync 24 hours after the program is restarted.
setSyncProvider(RTC.get);   // the function to get the time from the RTC
  setSyncInterval(86400);
Restart or reset the program some time after the evening alarm time.
Thank you, that is a good suggestion and I will give it a try.
I went out to check on the door this evening and it did not close, which has been the case for the last few days. However, I did notice that my 13 pin LED was lit up, which means the alarm did trigger but the full code in the trigger did not run. Now I'm feeling like all sorts of different issues are occurring at once. As I mentioned before, the same set of code worked fine for months and then stopped working.
I have to go out of town for a few days but when I get back I am going to try and rewrite the code so that I don't have multiple time/alarm libraries included. I don't have any evidence to support that there is a conflict between the multiple libraries but I'm thinking it will just be simpler to use only the RTC and run a loop that checks the time and runs my code at the correct time.
I guess I have 3 simple questions:
  • Is there anything obvious that I could be missing?
  • Does it make sense to rewrite the code using only RTClib.h for the timekeeping and alarm piece and remove Time.h and TimeAlarms.h?
  • Is there a possibility my Arduino hardware is glitching on me? Has anyone heard of the actual hardware causing buggy problems? This would make sense given that the code worked fine and now doesn't and no changes have been made to it.
Thanks for all the input so far, I really appreciate it. I will review any responses next week when I return.
Code does not just stop working. This tells me the problem is in the power supply, limit switch, door friction, the motor or motor motor driver, etc. Do you know whether the load on the stepper is higher with the door open or closed. How does the stepper actuate the door? What is the mechanical linkage? Failure to close certainly appears to be the dominant failure mode.
If it is the code it something subtle like the synch skipping over the alarm.
It can not hurt to eliminate the time and time alarms libraries. If the system still fails (and my bet is that it will) you will be more focused on the problem.
If the door close fails with the tell tale led activated and with the led off, you would think that you have two different problems. However, if the power supply to the arudino sags while trying to run the motor and the Arduino resets, then the led will be off even it was on when the motor tried to run but failed.
You have not posted full code which shows how the tell tale led is turned off after the sequence is successful, and is off waiting for the next alarm. Can you please post that code? A schematic of the connections between the Arduino, power supply, and motor would be helpful. Is the Arduino supply isolated from the motor supply or is the same supply run to the motor and into the barrel jack?
Cattledog, thanks for all the helpful advice.
I tried recoding by removing the time.h and timealarms.h libraries and solely using RTCLib.h per PaulS’s recommendation. I was able to run a blink test on the RTC alarms using the hour/minute function but it didn’t work when connected to the system. Probably for the same reasons the other code didn’t work.
I ended up buying a new Uno and new Adafruit Motorshield, loading the same code with no changes, and the door has been working perfectly now for a week with no hiccups. I guessing something was wrong with one of the boards or one of the connections between the boards was bad.
I can add the following to answer your question about power supply, limit switches, and schematics.
  • The power supply is a deep cycle RV battery (don’t laugh) charged by a 12v 20w solar panel
  • I use a step down to drop the voltage to 5.2v
  • I don’t think there is any voltage sag 8)
  • Now that you mention it, the limit switch might be an issue if moisture gets in there. The only reason I would rule that out is that when I press the manual button they system worked fine and I never had any issue with the limit switch.
  • I guess I ruled out all the other parts of the system because they worked fine when I manually pushed the button and time was the only part that didn’t work.
Again, thanks for all the help on this. It was really frustrating but I was really thankful to have someone to work it out with. Sorry for the delayed response, I was out of town and afk. Please let me know if any of you have ever had a faulty board so I can feel better about buy 2 new boards to solve the problem!
Only when there was also a room full of smoke. Darn hard to get that smoke back in.
Luckily, the smoke genie did not come out of the bottle. But who knows, maybe some component failed...I'm not skilled enough to figure out if that was the case and for $25 it was easier to get a new board.
I'm going to chalk this issue up to hardware failure because I simply loaded the same code on a new board setup and everything has been fine for over a week now.
Thanks for the RTC alarm suggestion vs using timealarms. I definitely see your point and it certainly slims down the code and makes it more efficient.
