timed av input selector switch
It is possible to make an off the shelf AV selector switch in to one where one input is timed and after a set duration switches back to the other input?
I have no idea what you mean. What's AV - Access Violation?
Sorry i mean audio visual like 2 RCA outputs going to 1 input
Like this
AV, or just V ?
Find out whether that switch operates on mechanical contacts or on electronics. If it's based on mechanics, find a relay with enough contacts, or replace it by a number of (Reed) relays. Or find a different switch, that is based on electronics. Then write the code to toggle that switch at given times.
So it sound like it would be possible and easier if the switch had electronic switches
