TimeLib error in returning correct date
Hi all,
I was trying to include the library to get date and time
here is the code that I used
include,TimeLib.h>
inside loop
tmElements_t tm ;
tm.Hour = 11; tm.Minute = 30; tm.Second = 45;
tm.Year = 2024; tm.Month = 2; tm.Day = 29;
makeTime(tm);
tm.Day +=1;
makeTime(tm);
Serial.print( tm.Day);
Serial.print( " - ");
Serial.print( tm.Month);
Serial.print( tm.Year);
Serial.print( " | ");
Serial.print( tm.Hour);
Serial.print( tm.Minute);
Serial.println( tm.Second);
This returns
13:25:37.468 -> 30 - 2 - 232 | 11 - 30 - 45
Note the Date is 30th Feb !!! It should be 1st March
why is this behavior ?
How to get the correct date from the above ? - adding or subtracting from the elements ?
I have use Time.h too
but gets the same output.
My requirement is very simple . add or substract seconds / minutes / hour / date with a given date to obtain a new date & time
So if I add 1 to 2024-Feb-29 , it should return 2024-Mar-1 , instead this return 2024-Feb-30 which obviously is wrong. How can I get correct date ? or is it that Time.h or TimeLib.h is inefficient for this simple operation ? if so what is the solution ?
tmElements_t tm ;
time_t epochTime = makeTime(tm);
time_t epochTime2 = epochTime + 24UL*60*60;
tmElements_t tm2 ;
breakTime(epochTime2, &tm2);
Serial.print( tm2.Day);
Serial.print( tm2.Month);
Serial.print( tm2.Year);
Serial.print( tm2.Hour);
Serial.print( tm2.Minute);
PaulRB,
Thank you so much. I really failed to understand the importance and use of epochTime. Thank you for showing.
PaulRB,
I am getting the following error.
error: invalid initialization of non-const reference of type 'tmElements_t&' from an rvalue of type 'tmElements_t*'
If the "&" is removed , it compiles, but the output is completely wrong. Any idea ?
That does not use the Time library, instead it references the standard C library. The actual header file is time.h, not Time.h, and will produce an error when compiling on an operating system, such as linux, that has a case-sensitive file system. The confusion between Time.h and time.h on Windows is a primary reason the header file for the Time library was changed to TimeLib.h.
The year in the tmElements_t struct is stored as the number of years since 1970, not the actual calendar year. The time library has the macros CalendarYrToTm() and tmYearToCalendar() to convert between the two representations. You are getting the wrong output because setting tm.year to 2024 is overflowing the single byte used to store the year value.
Since time_t represents the date/time in seconds, there are pre-defined values in the Time library for adding/subtracting common time intervals, such as SECS_PER_DAY for the number of seconds in a day.
#include <TimeLib.h>
  tmElements_t tm ;
  tm.Hour = 11;
  tm.Minute = 30;
  tm.Second = 45;
  tm.Year = CalendarYrToTm(2024);
  tm.Month = 2;
  tm.Day = 29;
  //time_t epochTime2 = epochTime + 24UL * 60 * 60;
  time_t epochTime2 = epochTime + SECS_PER_DAY;
  tmElements_t tm2 ;
  breakTime(epochTime2, tm2);
  Serial.print(tm2.Day);
  Serial.print(" - ");
  Serial.print(tm2.Month);
  Serial.print(tmYearToCalendar(tm2.Year));
  Serial.print(" | ");
  Serial.print(tm2.Hour);
  Serial.print(tm2.Minute);
  Serial.println(tm2.Second);
That did it. Thank you very much.
[ only thing is now I have to change a lot of code written for Time.h ]
Glad that it does work correctly. Thanks a lot every one.
A little more help pls.
I had use difftime() function to get difference between two times (Say 6:30 AM & 18:46 PM ) for computation. TimeLib.h doesn't seem to have that function. so How can I get this value from two tmElements_t ? thks
My approach is to convert the time and date to a unix timestamp, which is an unsigned long integer (the number of seconds since some epoch), and just subtract the earlier from the later.
In this example, I do the reverse, or add to get a later time/date:
//time_make_and_add
tmElements_t te;  //Time elements structure
time_t unixTime; // a time stamp
   // new internal clock setting.
  // convert a date and time into unix time, offset 1970
  te.Second = 0;
  te.Hour = 23; //11 pm
  te.Minute = 0;
  te.Day = 1;
  te.Month = 1;
  te.Year = 2017-1970; //Y2K, in seconds = 946684800UL
  unixTime =  makeTime(te);
  Serial.print("Example 1/1/2017 23:00 unixTime = ");
  Serial.println(unixTime);
  setTime(unixTime); //set the current time to the above entered
  Serial.print("now() = ");
  Serial.println(now());
  // print as date_time
  print_date_time();
  // add
  unixTime += 7200UL; //add 2 hours
  setTime(unixTime);
  Serial.println("After adding 2 hours");
  print_date_time();
void print_date_time() { //easy way to print date and time
  char buf[40];
  sprintf(buf, "%02d/%02d/%4d %02d:%02d:%02d", day(), month(), year(), hour(), minute(), second());
  Serial.println(buf);
void loop() {}
Found it !
sr.Hour = srH; sr.Minute = srM; sr.Second = 0;
sr.Year = CalendarYrToTm(y_ear); sr.Month = m_onth; sr.Day = d_ay;
time_t epochTimeR= makeTime(sr);
ss.Hour = ssH; ss.Minute = ssM; ss.Second = 0;
ss.Year = CalendarYrToTm(y_ear); ss.Month = m_onth; ss.Day = d_ay;
time_t epochTimeS= makeTime(ss);
time_t s_ecds = epochTimeS - epochTimeR ;
It is working nicely . Thanks to all who responded. Great people !!!!.
