TimeNTP Example have a problem
hello i will install time library with exaples i will run the timeserial example and i will run with processing and work FINE :slight_smile:
now i will try to run TimeNTP exampe but i have 2 errors but i dont know what its means
i have download and install the UdpBytewise.h/UdpBytewise.cpp in the directory /library/Ethernet/ because the TimeNTP wont this library..
this is the example
 * Time_NTP.pde
 * Example showing time sync to NTP time source
 * This sketch uses the Ethenet library with the user contributed UdpBytewise extension
#include <Time.h>
#include <Ethernet.h>
#include <UdpBytewise.h>  // UDP library from: bjoern@cs.stanford.edu 12/30/2008
#if  UDP_TX_PACKET_MAX_SIZE <64 ||  UDP_RX_PACKET_MAX_SIZE < 64
#error : UDP packet size to small - modify UdpBytewise.h to set buffers to 64 bytes
#endif
 * You may need to modify the UdpBytewise.h library to allow enough space in the buffers for the NTP packets.
 * Open up UdpBytewse.h and set the following buffers to 64 bytes:
 *    #define UDP_TX_PACKET_MAX_SIZE 64
 *    #define UDP_RX_PACKET_MAX_SIZE 64
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 44 }; // set the IP address to an unused address on your network
byte SNTP_server_IP[]    = { 192, 43, 244, 18}; // time.nist.gov
//byte SNTP_server_IP[] = { 130,149,17,21};    // ntps1-0.cs.tu-berlin.de
//byte SNTP_server_IP[] = { 192,53,103,108};   // ptbtime1.ptb.de
time_t prevDisplay = 0; // when the digital clock was displayed
const  long timeZoneOffset = 0L; // set this to the offset in seconds to your local time;
  Ethernet.begin(mac,ip);
  Serial.println("waiting for sync");
  setSyncProvider(getNtpTime);
  while(timeStatus()== timeNotSet)
     ; // wait until the time is set by the sync provider
  if( now() != prevDisplay) //update the display only if the time has changed
    prevDisplay = now();
    digitalClockDisplay();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
/*-------- NTP code ----------*/
unsigned long getNtpTime()
  sendNTPpacket(SNTP_server_IP);
  if ( UdpBytewise.available() ) {
    for(int i=0; i < 40; i++)
       UdpBytewise.read(); // ignore every field except the time
    const unsigned long seventy_years = 2208988800UL + timeZoneOffset;
    return getUlong() -  seventy_years;
  return 0; // return 0 if unable to get the time
unsigned long sendNTPpacket(byte *address)
  UdpBytewise.begin(123);
  UdpBytewise.beginPacket(address, 123);
  UdpBytewise.write(B11100011);   // LI, Version, Mode
  UdpBytewise.write(0);    // Stratum
  UdpBytewise.write(6);  // Polling Interval
  UdpBytewise.write(0xEC); // Peer Clock Precision
  write_n(0, 8);    // Root Delay & Root Dispersion
  UdpBytewise.write(49);
  UdpBytewise.write(0x4E);
  UdpBytewise.write(52);
  write_n(0, 32); //Reference and time stamps
  UdpBytewise.endPacket();
unsigned long getUlong()
    unsigned long ulong = (unsigned long)UdpBytewise.read() << 24;
    ulong |= (unsigned long)UdpBytewise.read() << 16;
    ulong |= (unsigned long)UdpBytewise.read() << 8;
    ulong |= (unsigned long)UdpBytewise.read();
    return ulong;
void write_n(int what, int how_many)
  for( int i = 0; i < how_many; i++ )
    UdpBytewise.write(what);
and this is the 2 errors give me back
In file included from TimeNTP.pde:10:
C:\Program Files\Arduino\libraries\Ethernet/UdpBytewise.h:70: error: conflicting return type specified for 'virtual void UdpBytewiseClass::write(uint8_t)'
C:\Program Files\Arduino\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
i really know what to do i dont have so much experience :slight_smile:
i have arduino IDE 1.0.5
and one more explanation i have the ethernt library from IDE 1.0.5 and there have the UdpNtpClient exaple this example work perfect.. maybe the time.h library dont work with this ethernet library ?
any help? thanks for your responce :slight_smile:
My installation of 1.0.5 doesn't even have this file:
I'm wondering why yours does.
hello Pauls
the time ntp example need this library and i will download .. before i doit and install it it have other erro such dont find this library ..
