Hi! using DHTstable test for DHT22, any idea what might be causing a timeout?
im just using the DHT tester 22 part of library but just getting this;
Thanks!
Phil
Thanks!
Phil
Please do not post pictures of code especially as it is so easy to right click in the IDE and select "Copy for Forum" and paste the code here complete with code tags
The same goes for Serial output which can be selected with the mouse then copied using Ctrl+C and pasted here in code tags
Read the forum guidelines.
Post code in code tags. Screenshots of code are nearly worthless.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
There are many dht11 libraries. Where did you get the one that you are using?
Post a schematic of your wiring.
Hi, apologies. Was more trying to share the error message and the code was just open.
But of course I'll share the serial part again properly, thanks for letting me know.
So copy and paste the Serial monitor output here in code tags
