I tried to upload a project in Arduino Mega 2560 but I was unsucessful.
I have a Windows 10 Pro 64 bits notebook and a Linux Ubuntu 14.04 64 bits desktop.
Both has Arduino IDE 1.8.3.
When I uploaded few codes i was successful but medium size codes I was not.
I set "Preferences" to show compile and upload warnings and I copied the results below.
I cut no interesting lines/warnings.
Sucess
@ Windows 10 Pro && Arduino 1.8.3
Arduino: 1.8.3 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 5970 bytes (2%) of program storage space. Maximum is 253952 bytes.
Global variables use 873 bytes (10%) of dynamic memory, leaving 7319 bytes for local variables. Maximum is 8192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM3 -b115200 -D -Uflash:w:C:\Users\ASFalcao\AppData\Local\Temp\arduino_build_307687/sketch_jul08a.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file "C:\Users\ASFalcao\AppData\Local\Temp\arduino_build_307687/sketch_jul08a.ino.hex"
avrdude: writing flash (5970 bytes):
Writing | ################################################## | 100% 0.98s
avrdude: 5970 bytes of flash written
avrdude: verifying flash memory against C:\Users\ASFalcao\AppData\Local\Temp\arduino_build_307687/sketch_jul08a.ino.hex:
avrdude: verifying ...
avrdude: 5970 bytes of flash verified
avrdude done. Thank you.
@ Ubuntu 14.04 && Arduino 1.8.3 64 bits
Sketch uses 11592 bytes (4%) of program storage space. Maximum is 253952 bytes.
Global variables use 1026 bytes (12%) of dynamic memory, leaving 7166 bytes for local variables. Maximum is 8192 bytes.
/home/afalcao/Downloads/arduino-1.8.3/hardware/tools/avr/bin/avrdude -C/home/afalcao/Downloads/arduino-1.8.3/hardware/tools/avr/etc/avrdude.conf -v -patmega2560 -cwiring -P/dev/ttyACM0 -b115200 -D -Uflash:w:/tmp/arduino_build_748469/ReadWrite.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 11:00:16
System wide configuration file is "/home/afalcao/Downloads/arduino-1.8.3/hardware/tools/avr/etc/avrdude.conf"
An error occurred while uploading the sketch
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
avrdude: reading input file "/tmp/arduino_build_748469/ReadWrite.ino.hex"
avrdude: writing flash (11592 bytes):
Writing | ################################################## | 100% 1.88s
avrdude: 11592 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino_build_748469/ReadWrite.ino.hex:
avrdude: 11592 bytes of flash verified
Unsuccessful
Sketch uses 22130 bytes (8%) of program storage space. Maximum is 253952 bytes.
Global variables use 1564 bytes (19%) of dynamic memory, leaving 6628 bytes for local variables. Maximum is 8192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM3 -b115200 -D -Uflash:w:C:\Users\ASFalcao\AppData\Local\Temp\arduino_build_572457/Heater-Monitor-v01.ino.hex:i
Using Port : COM3
avrdude: reading input file "C:\Users\ASFalcao\AppData\Local\Temp\arduino_build_572457/Heater-Monitor-v01.ino.hex"
avrdude: writing flash (22130 bytes):
Writing | #################################################avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x13
avrdude: stk500v2_paged_write: write command failed
| 100% 214.64s
There was the same error in a Linux desktop.
My you help me?
