Timeout Error while uploading on ATMega2560
I’ve a little problem with my new ATMega2560. Every time when I try to upload a sketch with Arduino IDE the following error occurs.
Loop-Back test was fine. My system is Win7 64bit.
It would be great if someone could help me!
Homerino
Timeout-Error:
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2000-2005 Brian Dean, [www.bdmicro.com]
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is “C:\Users\Jakob\Downloads\arduino-1.0.3-windows\arduino-1.0.3\hardware/tools/avr/etc/avrdude.conf”
Using Port : \.\COM6
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: wiring_open(): releasing DTR/RTS
avrdude: wiring_open(): asserting DTR/RTS
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
Start with a very simple sketch, for example the Blink sketch.
Are you sure you have selected the Arduino Mega 2560 board in the Arduino IDE ?
Do you use the “Upload” button or command, and not the “upload with programmer” command ?
I just tried it with the Blink sketch but the result is the same. And it's the same with all the other sketches :( Arduino Mega 2560 is selected and I always use the upload symbol.
I have the same "timeout communicating with programmer". I'm using Arduino Mega2560. I don't how can solve the problem. I reinstalled the deriver but still same problem.
Please help me .....
hi guys ....
I have a similar items with my mega compatible board before, but after struggling over I have manage to take my board back in normal with changing the AUTORESET CAPACITOR 100nF
see here http://www.arvydas.co.uk/wp-content/uploads/2010/01/arduino-reset-mod.jpg or you can google it.
I think my capacitor is defective.
Just give a try and hope you can solve this issue
My Mega2560 r3 came without any firmware installed, and it had similar symptoms. If the 16u2 chip and/or the bootloader need to be written, you might try the suggestions here. Be sure to note which rev you have, because that determines which USB chip may need initialization.
I had a similar issue, here is the solution:
http://forum.arduino.cc/index.php?topic=179489.0
