timeout error
I'm trying to make this project, the Altastation http://en.altapix.com/technique/altastation.html
It sends flight data from the the aircraft to an LCD on the ground.
I am using two Xbee Pro 2.4ghz units to communicate between the aircraft and the groundstation. The LCD shows the sketch starting when I power it up, but then it gives me an error, "D: Frame Timeout" and doesn't go any further. If I plug the Arduino directly into the aircraft serial output (eliminating the Xbees) then it all works fine and the flight data is displayed. I assume the Xbees are causing this error. I have played around with the Xbee settings for days. Any help would be much appreciated.
Thanks,
Julian
What sketch?
What series? How are they configured? Do you KNOW that they communicate with each other?
That's something your code is doing...
No, the XBees are not. The incorrect type of XBee, maybe. Mis-configured XBees, possibly. XBees out of range, maybe.
Too many unknowns to help you now.
