Timer 1 and Ethernet Shield Web Client
Im using Timer1 and Ethernet shield. I want to connect to a server every 5 seconds and do http GET.
Code below works. But is it the correct way of doing it? Do I need to call client.stop() and close connection every call of 'check' method?
thanks..
#include <TimerOne.h>
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,7);
EthernetClient client;
char server[] = "www.example.com";
String url;
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    Ethernet.begin(mac, ip);
  Timer1.initialize(5000000);
  Timer1.attachInterrupt(check);
void check() {
  //if there's a successful connection:
  if (client.connect(server, 80)) {
    client.println(...);
    client.println("Host: www.example.com");
    client.println("User-Agent: arduino-ethernet");
    client.println("Connection: close");
    client.println();
    client.stop();
  else {
    Serial.println("connection to server failed...");
    client.stop();
No. You only need to do that if ...
(See, I can snip relevant stuff, too).
