Hello there,
I am currently working on a project that is using mills to count between button presses, is there a way to have a high limit on that, say after 5000ms it automatically cycles the program as if the button was pressed?
if (timerRunning == 0 && digitalRead(button) == HIGH){
startTime = millis();
timerRunning = 1;
if (timerRunning == 1 && digitalRead(button) == LOW){
endTime = millis();
timerRunning = 0;
duration = endTime - startTime;
lowspeed = analogRead(POTL);
highspeed = analogRead(POTH);
Serial.print("LOW ");
Serial.print(lowspeed);
Serial.print("\t\t");
Serial.print("HIGH ");
Serial.println(highspeed);Serial.print ("time in milliseconds: ");
Serial.println (duration);
LarryD
June 11, 2021, 3:44pm
2
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch .
Use the </> icon from the ‘reply menu’ to attach the copied sketch.
Please explain a bit more.
include <Adafruit_DS3502.h>
Adafruit_DS3502 ds3502 = Adafruit_DS3502();
#define WIPER_VALUE_PIN A0
byte button = 2;
unsigned long startTime;
unsigned long endTime;
unsigned long duration;
byte timerRunning;
const int POTL = 1; // Pot on Analog Pin 1
const int POTH = 2; // Pot on Analog Pin 2
int lowspeed = 0; // Low speed set
int highspeed = 0; // High Speed set
int lowrpm = 0; // Low RPM kick in
int highrpm = 0; // High RPM kick in
pinMode (button, INPUT);
while (!Serial) {
delay(1);
Serial.println("Adafruit DS3502 Test");
if (!ds3502.begin()) {
Serial.println("Couldn't find DS3502 chip");
while (1);
Serial.println("Found DS3502 chip");
if (timerRunning == 0 && digitalRead(button) == HIGH) {
timerRunning = 1;
if (timerRunning == 1 && digitalRead(button) == LOW) {
endTime = millis();
timerRunning = 0;
Serial.println(highspeed); Serial.print ("time in milliseconds: ");
LarryD
June 11, 2021, 4:05pm
4
sugakane:
timerRunning == 1
Make/start a 5 second TIMER then when you set timerRunning = 1 .
When the TIMER finishes, you can do what needs to be done.
unsigned long timerMillis;
//not tested
timerRunning = 1;
//start the 5 second TIMER
timerMillis = millis();
if(timerRunning == 1 && millis() - timerMillis >= 5000)
timerRunning = 0;
//do your stuff here
system
Closed
October 9, 2021, 4:05pm
5
