Timer configuration?
Up to now I used timers on my Due for different tasks (interrupts, frequency generation). Now I don't understand what's wrong with following configuration of a timer to generate a timeout signal:
// configure Timeout-Timer TIOB2/PA6/Periph.A
void configTIOB2(uint8_t secs) {
  PMC->PMC_PCER0 = PMC_PCER0_PID29;   // clock enable TC2 with ID=29
  PIOA->PIO_ABSR &= !PIO_ABSR_P6;     // multiplexer pin PA6 to peripheral A for TIOB2
  PIOA->PIO_PDR = PIO_PDR_P6;         // GPIO for pin PA6 deactivate
  TC0->TC_CHANNEL[2].TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK4 |  // MCK/128 = 656,25 kHz
                              TC_CMR_WAVE |                 // Wavemode
                              TC_CMR_WAVSEL_UP |         // cnt up, RC compare not triggers
                              TC_CMR_BCPB_SET |             // RB compare sets TIOB to high
                              TC_CMR_BCPC_CLEAR |           // RC compare sets TIOB to low
                              TC_CMR_CPCSTOP |              // RC compare stops clock
                              TC_CMR_BSWTRG_CLEAR;          // SW trigger sets TIOB to low
  TC0->TC_CHANNEL[2].TC_RB = 656250 * secs;           // TIOB2 high after 4 secs
  TC0->TC_CHANNEL[2].TC_RC = 656250 * (secs+1);       // TIOB2 low after 5 secs
  // enable and start occurs outside
  SerialUSB.begin(0);  // fuer Print-Ausgaben
  while (!SerialUSB);
  while (1) {
    SerialUSB.print(F("Start Timer  "));
    TC0->TC_CHANNEL[2].TC_CCR = TC_CCR_CLKEN | TC_CCR_SWTRG;  // Timeout clock enable, start
    SerialUSB.print(TC0->TC_CHANNEL[2].TC_CV);    // look at counter value
    SerialUSB.print(" ");
    delay(3000);
    SerialUSB.println(TC0->TC_CHANNEL[2].TC_CV);
    SerialUSB.println(F("TIOB2?"));
My PC is connected to the Due Programming Port.
A second USB cable is connected to the Due Native USB Port (SerialIUSB).
A volt meter is connected to pin A4 (PA6). It should show low level for 4 sec and high level for 1 sec. But there is low level all the time!
The print outs look like:
Start Timer 655660 1311913 3280662
TIOB2?
Start Timer 655644 1311897 3280646
TIOB2?
The timer is running 655660 steps per second, but TIOB2 on pin A4 is low all the time :disappointed:
What is wrong?
remark: when you are testing the sketch on a Due and do some changes then you should disconnect the USB cable from the Native Port during compilation.
Hi, I found it:
It is necessary to set EEVT to a value>0, because EEVT=0 means TIOB is used as external event and not available as output. And by default EEVT=0.
