Hello,
I am using Arduino Due and I am using the all the Timer counter 9 of them independently to creat PWM wave but I am stuck with timer 1 is not working, I dont know if I need to change something in the code. I use all the digital pins that is related to the timer counter and I still need one and I am trying with Analog pin 7 A7 on arduino Due, because in the datasheet of SAM , it shows that I can use it.
can I use this analog pin to create the pwm through timer counter
#define STEP_PIN_61 61 // motor 8
float frequency = 10000.0;
pinMode(STEP_PIN_61, OUTPUT);
setupTimer5();
void setupTimer5() {
PMC->PMC_PCER0 |= PMC_PCER0_PID28; // // Enable peripheral TC1 (TC0 Channel 1)
PIOA->PIO_ABSR |= PIO_ABSR_P2; // the multiplexer to peripheral A for TIOA1 , D61
PIOA->PIO_PDR |= PIO_PDR_P2; // Disable the GPIO on the corresponding pins
volatile int32_t rc = (84000000 / 2) / frequency; // //by PWM_FREQUENCY Velocity = TIMER_CLOCK / RC.
TC0->TC_CHANNEL[1].TC_CMR = TC_CMR_BCPC_SET | // Set TIOB on counter match with RC0
TC_CMR_ACPC_SET | // Set TIOA on counter match with RC0
TC_CMR_BCPB_CLEAR | // Clear TIOB on counter match with RB0
TC_CMR_ACPA_CLEAR | // Clear TIOA on counter match with RA0
//TC_CMR_ABETRG | // TIOA is used as the external trigger
TC_CMR_WAVE | // Enable wave mode
TC_CMR_WAVSEL_UP_RC | // Count up with automatic trigger on RC compare
//TC_CMR_EEVT_XC0 | // Set event selection to XC0 to make TIOB an output make an output
TC_CMR_TCCLKS_TIMER_CLOCK1; // Set the timer clock to TCLK1 (MCK/2 = 84MHz/2 = 42MHz)
TC0->TC_CHANNEL[1].TC_RA = rc / 2; // Load the RB0 register TIOA1
TC0->TC_CHANNEL[1].TC_RC = rc; // Load the RC0 register period
//NVIC_SetPriority(TC7_IRQn, 0); // Set the Nested Vector Interrupt Controller (NVIC) priority for TC6 to 0 (highest)
NVIC_EnableIRQ(TC1_IRQn); // Connect TC6 to Nested Vector Interrupt Controller (NVIC)
TC0->TC_CHANNEL[1].TC_IER |= TC_IER_CPCS; // Enable interrupts for TC7 (TC2 Channel 1)
TC0->TC_CHANNEL[1].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN; // Enable the timer TC7
void TC1_Handler() {
uint32_t status = TC0->TC_CHANNEL[1].TC_SR; // Read the status register of Channel 1
