Timer/for 1 hour
Project where if an input is triggered and if the condition is not cleared after 1 hour a buzzer is triggered. Other routines need to continue to run during the one hour period. what would be some of the methods to accomplish that?
Along these lines:
boolean condition = false;
  // read button;
  isOn = digitalRead(BTN_PIN);
  if (isOn && !condition)
    // start 1-hour timer;
    lastMillis = millis();
    condition = true;
  if (condition && (millis() - lastMillis >= 3600L * 1000))
    // 1 hour passed; ring the bell;
    // reset the condition for a new 1-hour timer;
florinc Awesome I'll give it a try.
Can I ask what the "L" means in 3600L. I have seen it used before.
L
Navigator_x2:
it tells the compiler to treat 3600 as a long value (32bit) instead of int (16bit).
the compiler will use the smallest possible memory storage to calculate a value, each value is
treated individually, so if you have an equation such as:
unsigned long longVar = 1000 * 1000; // you would expect the answer to be 1000000,
  // but it longVar would equal 16960 because 1000 will fit in a 16bit int, a 16bit * 16bit = 16bit
// any value that overflows is lost
unsigned long longVar = 1000L * 1000; // causes the compiler to promote all of the constants
// on the right side to longs (32bit) so the answer is now 1000000
Chuck.
florinc:
Along these lines:
  // read button;
    condition = true;
nice snippet of code.
add a RTC and you can chime a clock every hour.
add
// if (worldEnd=TRUE){ commented out to save the world.
if (worldEnd==TRUE){
end program
and it could go on for as long as we are here.
Thanks All
This maybe what I was looking for in this project. I will play with the examples.
All the answers and help is appreciated as always.
Cheers
dave-in-nj:
add
if (worldEnd=TRUE){
end program
Oops!
Using a single equals sign will set worldEnd to TRUE.
You don't want that, do you?
odometer:
Oops!
YIKES !
the DESTRUCTOR of worlds with 1 line of code.....
dave-in-nj:
add
end program
whew ! thanks odometer,
your observant eye may have single handedly saved the future of the human race.
I always thought the world would end by: climate change, or asteroid, or comet, or nuclear war, or polar shift, but not an Arduino! :o
What is the OP really trying to do, should we even consider helping, we could be the author of our own demise :wink:
