Timer for turning the LED off
Hi everyone,
I'm pretty new to the Arduino and I'm struggling with a part of my code.
I'm trying to turn the LED on, if the value X on my sensor is below 500, and turn it off when it is above.
Now I want to implement a timer (from a serial terminal input for values 1-50 seconds). And here comes the issue. I want that whenever the LED is supposed to turn OFF (the value X is above 500), the LED will remain ON for the duration of the timer that was set (using the serial terminal) and then after the timer expires it turns the LED off. Unfortunatelly, my code turns the LED off immedietely after the sensor value X is above 500.
Could you please help me with this issue?
Thank you!
int X = 0;
long timer = 4000; //begins with 4 seconds
unsigned long timeMillis;
unsigned long previousTime = 0;
  Serial.println("Enter timer - from 1 to 50 seconds: ");
  //LED output
  pinMode(8, OUTPUT);
  X = analogRead(1);
  if(Serial.available()) {
    //reading the input command for on time
    String time = Serial.readStringUntil('\n');
    time.trim();
    timer = time.toInt();
     if(timer >= 1 && timer <= 50){
      timer = timer * 1000;
     else {
      Serial.println("Your number doesn't fit in the range");
      timer = 4000;
  //Turn the LED on if it's below 500
  if(X < 500){
    digitalWrite(8, HIGH);
  //Turn the LED off if it's above 500
  else if (X >= 500){
    timeMillis = millis();
    Serial.println(timeMillis);
    Serial.println(previousTime);
    if ((timeMillis - previousTime) >= timer){
      previousTime = timeMillis;
      digitalWrite(8, LOW);
Always show us a good schematic of your proposed circuit. Show us a good image of your ‘actual’ wiring. Give links to components.
What do you get if you print this back to the serial monitor ?
X = analogRead(1);
Are you using A1 or A0 ?
BTW, make things explicit:
X = analogRead(A1);
Set a Flag variable when above is true.
Disable reading A1 when the Flag is set.
Use the Flag to enable the TIMER.
When the TIMER expires, clear the Flag.
Try this. Not tested, and I'm tired and slightly tipsy, so please don't get your hopes up too soon...
int X = 0, prevX = 0;
  //LED output
  pinMode(8, OUTPUT);
  X = analogRead(1);
    time.trim();
     else {
      timer = 4000;
  if(X < 500 && prevX >= 500){
  //Set timer if it's above 500
  if (X >= 500 && prevX < 500){
  //Turn led off if timer is up
  prevX = X;
:face_with_spiral_eyes:
Too much football ?
In my book, any football is too much football. For me. I understand many love it. :grinning:
Same here.
Are you doing this to avoid rapidly turning on and off when the analog input is near the detection threshold? A timer is not the best solution for that. Use hysteresis instead.
