Hey guys, I have troubles with my project..
This project reads data from a sensor sends it to an ESP32 and displays it on a web dashboard via the cloud iot servie called blynk.
Over the web dashboard I can control humidity, temperature, etc. I am currently trying to implement a timer for swiching on and off a devices (Pin 12 and Pin 27) which can be customised over the web dashboard. I want to modify the duration for the device is running and i want to modify how long the device should stop running.
I tried to solve this with the two int: airflowduration
and airflowdelay
The value of those two int can be changed anytimes and gets displayed correctly in the serial monitor. But however the timer does not work. When i replace the two int with normal numbers it works.
row 138: timer.setTimeout(airflowduration, []()
row 195: timer.setInterval((airflowdelay + airflowduration), Airflow);
Thats the full code:
This is a library for the CCS811 air
This sketch reads the sensor
Designed specifically to work with the Adafruit CCS811 breakout
----> http://www.adafruit.com/products/3566
These sensors use I2C to communicate. The device's I2C address is 0x5A
Adafruit invests time and resources providing this open source code,
please support Adafruit andopen-source hardware by purchasing products
from Adafruit!
Written by Dean Miller for Adafruit Industries.
BSD license, all text above must be included in any redistribution
//set Serial Monitor ro 115200 baud
// Fill-in information from your Blynk Template here
#define BLYNK_TEMPLATE_ID "TMPL6siRfUN2"
#define BLYNK_DEVICE_NAME "MushcubePrototype"
#define BLYNK_FIRMWARE_VERSION "0.1.0"
#define BLYNK_PRINT Serial
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
//#define USE_TTGO_T7
//#define USE_ESP32C3_DEV_MODULE
//#define USE_ESP32S2_DEV_KIT
#include "BlynkEdgent.h"
#include <Wire.h>
#include "Adafruit_CCS811.h"
#include "ClosedCube_HDC1080.h"
ClosedCube_HDC1080 hdc1080;
Adafruit_CCS811 ccs;
BlynkTimer timer;
int humidity;
int temp;
int co2;
int TVOC;
int airflowduration;
int airflowdelay;
int humiditycontrol; // Now declared globally
int temperaturecontrol; // Now declared globally
BLYNK_WRITE(V4)
//Controlls Humidity on Pin14
humiditycontrol = param.asInt();
Serial.print("BLYNK_WRITE(V4)triggered - incoming value = ");
Serial.println(humiditycontrol);
BLYNK_WRITE(V5)
//Controlls Temperature on PinX !To enanble this funtion, assign new pin and remove //
temperaturecontrol = param.asInt();
Serial.print("BLYNK_WRITE(V5)triggered - incoming value = ");
Serial.println(temperaturecontrol);
// Don't do this here, do it in sensorDataRecive()...
//if (temperaturecontrol > temp)
// digitalWrite(15, HIGH);
//else
//digitalWrite(15, LOW);
BLYNK_WRITE(V6)
//Sets value for airflowduration from the cloud and prints it in serial monitor
airflowduration = param.asInt();
Serial.print("BLYNK_WRITE(V6)triggered - incoming value = ");
Serial.println(airflowduration);
airflowduration = airflowduration * 1000;
Serial.print("airflowduration in ms = ");
BLYNK_WRITE(V7)
//Sets value for airflowdelay from the cloud and prints it in serial monitor
airflowdelay = param.asInt();
Serial.print("BLYNK_WRITE(V7)triggered - incoming value = ");
Serial.println(airflowdelay);
airflowdelay = airflowdelay * 1000;
Serial.print("airflowdelay in ms = ");
BLYNK_WRITE(V100)
//Controlls TestLED on Pin12
int pinValue = param.asInt();
digitalWrite(12,pinValue);
Serial.print("BLYNK_WRITE(V100)triggered - incoming value = ");
Serial.println(pinValue);
void Airflow() //swiches Fans on and off for a certain time
digitalWrite(27, HIGH); //swiches fan1 on
digitalWrite(12, HIGH); //swiches fan2 on
//airflowduration = * 1000;
Serial.print("In void Airflow - airflowduration in ms = ");
Serial.print(airflowduration);
Serial.println(" Timer starting");
// When the timer completes, any code here will be executed
digitalWrite(27, LOW); //swiches fan1 off
digitalWrite(12, LOW); //swiches fan1 off
Serial.print("Timer complete - AIRFLOW OFF FOR ");
Serial.print(airflowdelay);
Serial.println(" ms");
//ccs811 start
Serial.println("CCS811 test");
if(!ccs.begin())
Serial.println("Failed to start sensor! Please check your wiring.");
while(1);
// Wait for the sensor to be ready
while(!ccs.available());
hdc1080.begin(0x40);
//ccs811 end
pinMode(12, OUTPUT); //Pin 12 is an Output pin
pinMode(14, OUTPUT); //Pin 14 is an Output pin
pinMode(27, OUTPUT); //Pin 27 is an Output pin
BlynkEdgent.begin(); //runs Blynk Connection Liberary
//timer.setInterval(20*1000L, SerialMonitor); //runs void CCS811 every X*1000ms
//delay(200);
timer.setInterval(10*1000L, sensorDataRecive); //runs void sensorDataRecive every X*1000ms
//delay(200);
//timer.setInterval(10*1000L, sensorDataSend); //runs void sensorDataSend every X*1000ms
BLYNK_CONNECTED()
Blynk.syncVirtual(V4); //HumidityControl
Blynk.syncVirtual(V5); //AirflowDuration
Blynk.syncVirtual(V6); //AirflowDuration
Blynk.syncVirtual(V7); //AirflowDelay
Serial.print("Setting timer to ");
Serial.print(airflowdelay + airflowduration);
// note that this timer duration won't change until the device re-starts.
// probably need to delete the timer and re-create if different functionality is needed...
void sensorDataSend()
// this code moved into sensorDataRecive
void SerialMonitor() // Timer that trtiggers this is disabled
//BLYNK_WRITE (V4)
Serial.println(" ");
Serial.println("------------------------------------------------------");
Serial.println(" Additional Outputs ");
Serial.println(" Blynk user settings:");
Serial.print(" RH: ");
Serial.print(humiditycontrol);
Serial.print("%");
//BLYNK_WRITE (V5)
Serial.print(" Temp: ");
Serial.print(temperaturecontrol);
Serial.println("°C");
//BLYNK_WRITE (V6)
Serial.print(" Airflow - duration set by user at: ");
Serial.println("sec");
//BLYNK_WRITE (V7)
Serial.print(" Airflow - delay set by user at: ");
Serial.println("min");
//Sensor CJMCU 8118
Serial.println(" Sensor CJMCU 8118 meassurements:");
Serial.print(" RH=");
Serial.print(hdc1080.readHumidity());
Serial.print("% Temp=");
Serial.print(hdc1080.readTemperature());
if(ccs.available()){
if(!ccs.readData())
Serial.print(" CO2: ");
Serial.print(ccs.geteCO2());
Serial.print("ppm TVOC: ");
Serial.println(ccs.getTVOC());
else{
Serial.println("ERROR!");
while(1);
void sensorDataRecive()
// You can't do this, leave these commented-out...
//Blynk.syncVirtual(V4); //HumidityControl
//Blynk.syncVirtual(V5); //TemperatureControl
//Blynk.syncVirtual(V6); //AirflowDuration
//Blynk.syncVirtual(V7); //AirflowDelay
//Blynk.syncVirtual(V8); //CO2 Control
humidity=hdc1080.readHumidity()+4;
temp=hdc1080.readTemperature()-4;
co2=ccs.geteCO2();
TVOC=ccs.getTVOC();
Blynk.virtualWrite(V0, humidity);
Blynk.virtualWrite(V1, temp);
Blynk.virtualWrite(V2, co2);
Blynk.virtualWrite(V3, TVOC);
if (humiditycontrol > humidity)
digitalWrite(14, HIGH);
digitalWrite(14, LOW);
BlynkEdgent.run();
timer.run();
Thats what the serial monitor says:
19:31:20.810 -> [17002] CONNECTING_NET => CONNECTING_CLOUD
19:31:20.848 -> [17033] Connecting to blynk.cloud:443
19:31:22.963 -> [19154] Certificate OK
19:31:22.997 -> [19186] Ready (ping: 30ms).
19:31:23.148 -> BLYNK_WRITE(V4)triggered - incoming value = 23
19:31:23.224 -> BLYNK_WRITE(V5)triggered - incoming value = 28
19:31:23.295 -> BLYNK_WRITE(V6)triggered - incoming value = 11
19:31:23.295 -> airflowduration in ms = 11000
19:31:23.328 -> Setting timer to 11000 ms
19:31:23.328 -> [19527] CONNECTING_CLOUD => RUNNING
19:31:23.328 -> BLYNK_WRITE(V7)triggered - incoming value = 21
19:31:23.362 -> airflowdelay in ms = 21000
19:31:34.341 ->
19:31:34.341 -> In void Airflow - airflowduration in ms = 11000 Timer starting
19:31:45.311 ->
19:31:45.311 -> In void Airflow - airflowduration in ms = 11000 Timer starting
19:31:45.311 ->
19:31:45.311 -> Timer complete - AIRFLOW OFF FOR 21000 ms
19:31:56.325 ->
19:31:56.325 -> In void Airflow - airflowduration in ms = 11000 Timer starting
19:31:56.325 ->
19:31:56.325 -> Timer complete - AIRFLOW OFF FOR 21000 ms
19:32:07.305 ->
19:32:07.305 -> In void Airflow - airflowduration in ms = 11000 Timer starting
19:32:07.338 ->
19:32:07.338 -> Timer complete - AIRFLOW OFF FOR 21000 ms
19:32:18.432 ->
19:32:18.432 -> In void Airflow - airflowduration in ms = 11000 Timer starting
19:32:18.432 ->
19:32:18.432 -> Timer complete - AIRFLOW OFF FOR 21000 ms
19:32:29.339 ->
19:32:29.339 -> In void Airflow - airflowduration in ms = 11000 Timer starting
19:32:29.424 ->
19:32:29.424 -> Timer complete - AIRFLOW OFF FOR 21000 ms
19:32:40.327 ->
19:32:40.327 -> In void Airflow - airflowduration in ms = 11000 Timer starting
19:32:40.327 ->
19:32:40.327 -> Timer complete - AIRFLOW OFF FOR 21000 ms
19:32:51.301 ->
19:32:51.301 -> In void Airflow - airflowduration in ms = 11000 Timer starting
19:32:51.340 ->
19:32:51.340 -> Timer complete - AIRFLOW OFF FOR 21000 ms
