i am a project with function user need to press button a total of 10 sec and led will on .After Led on for 5sec the system will reset and user need press again
Press and hold 10sec LED ON
Press and release and press again LED will still ON if total timing added together is 10sec
LED on for 5sec then off
You need to record when the switch becomes pressed. The state change detection example, and the millis() function, might be useful.
You need to check, periodically, if the switch is pressed and, if it is, how long it has been pressed. If it has been pressed for long enough, turn the LED on and record when you did that.
You need to check, periodically, if the LED is on, and, if is is, how long it has been on. If it has been on for long enough, turn it off.
Switch is closed and as long as switch remains closed, the LED remains OFF. Is this statement correct?
If switch gets opened within 10-sec time, the LED becomes ON. Is this statement correct?
If 10-sec time is elapsed with switch at closed condition, the LED becomes ON. Is this statement correct?
Let the LED remain ON for 5-sec; after that, the MCU will automatically be reset; the program will be re-executed from the beginning. Is this statement correct?
To be more clear
If switch is press and for 10sec (he can press in 1 shot or press,release and press again for total 10 sec)
LED ON
After LED ON for 5sec auto Off and reset the program
Alextak:
To be more cler
LED ON
I had a plan to draw a flow chart for the solution of your problem; now, I have difficulties as I don't understand at all what you have stated in the above quote.
GolamMostafa:
what I meant is the user can press and hold for 10sec OR
user can press for 1sec and release and press 9sec
user can press for 2sec and release and press 8sec
user can press for 3sec and release and press 7sec
user can press for 4sec and release and press 6sec
user can press for 5sec and release and press 5sec
user can press for 1sec and release and press 2sec and release 7sec
so user can on the LED by pressing the button for 10sec in total
Alextak:
User can press switch and hold it for 1 sec; (during this time LED is ON or OFF?)
User then releases (open) the switch and the switch remains open for how long?(Say 2 sec) (during this time LED is ON or OFF?
User then presses switch and hold it for 7 sec (during this time LED is ON or OFF?)
How to do you want to force the MCU to point at the reset vector?
