Timer inaccuracy when not using delay()
I’m just getting started with Arduino, so after working through some of the basic examples, I wanted to write some code that would display on an lcd screen a count of mm:ss since arduino start up.
The code I came up with is:
#include<LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 8, 7, 6, 5);
unsigned long minutes;
unsigned long seconds;
unsigned long currentTime;
unsigned long loopStartTime;
unsigned long loopEndTime = -1000;
unsigned long refreshInterval = 1000;
void getTime()
  currentTime = millis();
  minutes = currentTime / 60000;
  seconds = (currentTime % 60000) / 1000;
  lcd.begin(16, 2);
  loopStartTime = millis();
  if (loopStartTime - loopEndTime >= refreshInterval)
        loopEndTime = loopStartTime;
        getTime();
        lcd.setCursor(12, 1);
        lcd.print(minutes);
        lcd.print(":");
        if (seconds < 10)
          lcd.print("0");
          lcd.print(seconds);
          lcd.print(seconds);
The issue I’m finding is that compared to a stopwatch the arduino takes 00:15 to register 00:10. If I add a short delay at the end of the loop (say 100ms) it fixes the problem and the Arduino keeps time, but I want to avoid using a delay so I can monitor for button presses etc.
Could anyone advise why adding a delay is helping the code keep accuracy?
Kind Regards
these are integer division operations
why don't you try
seconds = (currentTime / 1000) % 60;
Also, the set up() function and what happens prior to setup() takes a few seconds. Do not start your stopwatch when you apply power.
