Timer Interrupt Problem
Hey
The LED should toggel every second, but the LED needs 4s to switch.
unsigned int timerCounter = 0;
  //intialize Timer
  TIMSK0 = _BV(OCIE0A);  // Enable Interrupt TimerCounter0
  TCCR0A = _BV(WGM01);  // Mode = CTC
  TCCR0B = _BV(CS01)|_BV(CS00);   // 64 Prescaler
  OCR0A = 125;          // 0,0001s
  sei();
  pinMode(13, OUTPUT);
ISR(SIG_OUTPUT_COMPARE0A)
  timerCounter++;
  if(timerCounter==10000)
    digitalWrite(13, HIGH);   // set the LED on
  if(timerCounter>=20000)
    digitalWrite(13, LOW);    // set the LED off
    timerCounter=0;
My Calculation is: 1/1600000064125=0,00001s
Where is the failure?
Thanks, Nikolausi
My calculation is 1/ 16.000.000 * 64 * 125 = 0.0005 so at least something in your math is incorrect.
